good morning,
how many users can rb3011 handles in user manager.
regards
James
good morning,
regards
James
Its not about the Model… It depends on the License Level of each model…
RB3011 has a Level 5 License ( L5 ), which means 500 active hotspot users …
… And L5 is 50 active usermanager sessions.
So in this case 50 is the limit, no? (There can be more users defined in usermanager, but only 50 will be active in the usermanager session-lists and tables)
Well right, the OP says about user manager and not hotspot users…
So its 500 hotspot users and 50 user manager active users ( if only user manager is used then 50 will be the max users , however hotspot users can be created as well from the users profile on the MikroTIK side )…
And where do you find the magic license information??
Found it.
https://help.mikrotik.com/docs/display/ROS/RouterOS+license+keys
@anav, there was a link on post #2 …
Silly me… Thanks!
