Usermanager
Hello all.
Thanks for the latest stable update. It's a pleasure. Good job to all the Mikrotik Team.
Please i have an issue with the usermanager package.
I've installed it, normally, but i can't have access to it trougth the /tool/usermanager as we did in the past.
The option don't exist in winbox (4.0beta9) or in webfig.
I have activated the package more thant 4 times, with GUI and command line, but the option still don't exist or don't work.
Please i need your help.
Here are some configurations :
eset-button usb export print
[GNG@MikroTik] > system/routerboard/print
routerboard: yes
model: RB2011UiAS-2HnD
revision: r2
serial-number: B9070AC04CB2
firmware-type: ar9344
factory-firmware: 6.42.12
current-firmware: 7.2.3
upgrade-firmware: 7.16.1
[GNG@MikroTik] > /system/ package print
Columns: NAME, VERSION, BUILD-TIME, SIZE
NAME VERSION BUILD-TIME SIZE
0 routeros 7.16.1 2024-10-10 14:03:32 10.1MiB
1 wireless 7.16.1 2024-10-10 14:03:32 1464.1KiB
2 user-manager 7.16.1 2024-10-10 14:03:32 372.1KiB
3 iot 7.16.1 2024-10-10 14:03:[flash=][flash=]32 552.1KiB [/flash][/flash]
[GNG@MikroTik] > tool
bandwidth-server sniffer flood-ping snmp-get
e-mail traffic-generator ip-scan snmp-walk
graphing traffic-monitor mac-scan speed-test
mac-server bandwidth-test mac-telnet torch
netwatch dns-update ping traceroute
romon export ping-speed wol
sms fetch profile
The configuration is found under /user-manager/ https://help.mikrotik.com/docs/spaces/ROS/pages/2555940/User+Manager
Thanks a lot.
Please just to know, there is GUI option for user-manager ?
Everything is ok know.
Maybe it was a bug.
Thanks everyone. You can close this post.
