Username & password authentication in DHCP
dears,
Can any one help me about to make authentication (user name & pass) in dhcp server.
i mean that if any dhcp user wish to use internet then he/she may have to authenticated by username and pass also.
We can use PPPOE but i need to make authentication in DHCP mode.
so if anybody help to ab this then i will be so gratefull to him.her.
It’s so urgent …plz HELP me
regards…
:frowning:
yes,
i think DHCP-Hotspot will help, cos with it module you can easy to make control them.
mikrotik's module more friendly... :wink:
regrads
Hasbullah.com
hotspot uses a lot of cpu power. we are using it to authticate now, every time a client log in, cpu hits 100% since hotspot has to add a queue and etc..
then cpu usage comes down to normal around 10%. machine is a p4 2133freq. with 200 users.
we are wanting to move away from this setup. we would like to keep the login name/ password setup. but not so many queus.
Have not found a solution yet
you can use user manager or RADIUS to assign speed limitations, keeping user database off the router will help.
Dear ,
Plz need the proper solution that u want to understood…
would u plz wirte in detail..then i will be gratefull to u
awaiting for ur kind brief description
—>>> ( APU )
basics: http://www.mikrotik.com/testdocs/ros/2.9/ip/hotspot.php
manual: http://www.mikrotik.com/pdf/hotspot.pdf
hotspot is very easy, just click on hotspot “SETUP” in winbox.
The other option is to use a single sharing queue rather than assigning a per user queue.
This depends on what the usage habits are like thou as it will allow a faster connection for the most part, but is more open to people abusing the speed.
We had approx 300 users on 2 different locations, 1 with a slower connection 1 faster.. the faster 1 was often maxing 100% cpu and changing it to the single queue helped a fair bit.
Use PCQ,
http://wiki.mikrotik.com/wiki/PCQ_Examples
but you have to configure queue manually on the router, it is not possible to make PCQ queue in automatic way.
