Users changing their password remotely via UserManager
Hello, please i’m having difficulty with this.
I have RouterOS 5.19V running on a PC, hotspot running and using UserManager as RADIUS. The issue is that i want to allow active user accounts to be able to change their password remotely without logging into the usermanager interface as a customer.
Please i’ll appreciate if anyone can help with this. I am at my wits end.
THanks.
usermanager customers login panel:
http://[your-router-ip]/userman
usermanager normal users login panel:
Thanks korderlink.
I have tried it, but it didn’t work. I put “http://my-router-ip/user” into the address bar on a browser, it showed ‘Error 404: not found’
When i log in into the usermanager via “http://my-router-ip/userman”, it did show i have 1 active user and 1 active session.
Please i need to allow user-managers user accounts to change password, without the attention of the operator.
I will appreciate every useful clue.
Thanks.
First, user must login hotspot to access usermanager panel:
  1. user login hotspot → http://[my-hotspot-ip]/login
  2. user login usermanager → http://[my-router-ip]/user
To access usermanager, You must use the IP address that is not used by the hotspot server.
hi dude,
its works
Thanks koderlink! It worked…the info was so helpful.
I have been a naught all the while, don’t mind me.
Firstly, i had to use a different ip address(not hotspot ip) as my RADIUS ip and same for the usermanager setup.
Then, i accessed the user login panel with the radius ip/user. e.g. http://192.168.10.1/user. All the while i had been using the exact login name of the user accounts i created in the usermanager database in the url i.e. http://192.168.10.1/test (‘test’ being a user account), instead of just user.
Thanks awfully for the information.
I still can’t access it.
My hotspot network ip is 192.168.1.1, I have tried to change the ip of the radius and the usermanager ip,
using the same ip like 192.168.10.1 (i putted 127.0.0.1 for both of them). But i can’t access the http:///user to change the password.
Could you please put more detail example ?
Regards,
Djemmy
dear djynny ,
use your waln iP which is not your hotspot ip
ex.
WAN ip = 192.168.88.1 (ether1)
LAN ip = 192.168.1.1 ( hotspot IP / ether2)
now try with http://192.168.88.1/user , from hotspot user who already login
@karma good job. Please am so much interested in how you converted your ip address into names. it is cool. I have searched this forum for an answer about this but got none. Please share it with us.
Thanks.
hi
i have this problem
i can open this page 192.168.0.100/user very good , but when i put the user " for customer " and password show me invalid username or password
I have tried it from this… please some help
How we do it in usermanager routeros 7?
I can login via http://[ip-usermanager]/um
but I can’t find the change password feature
i have try this only work for ros 6
