Users Created in Hotspot starts counting from begining
Hello all,
Please i am having serious issues with my rb751 with usb. I have configured hotspot and usermanager working very fine. All of a sudden i started noticing strange behaviour in my MT. If a user created in hotspot thru winbox is logged on, as soon as there is power outage on the MT, the time starts counting back to the period he was initially.
Let me explain it more in details with instances; userA bought 1hr, as soon as he logged in, and used like 30mins, and the Router goes off n comes on as a result of power outage, his time will start counting again from 1hr, instead of 30mins. I have tried creating users in user-manager, the same thing happens. How do I come out of this or rectify this problem as it has affected the people. below is my configuration from the router.
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 5.22 (c) 1999-2012 http://www.mikrotik.com/
[admin@technoplus cafe] > export
jan/01/2002 02:22:20 by RouterOS 5.22
software id = JJM5-9EMA
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes
disabled=no forward-delay=15s l2mtu=1598 max-message-age=20s mtu=1500 name=
bridge1 priority=0x8000 protocol-mode=none transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=
no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:FC:B1:FA master-port=
none mtu=1500 name=ether1 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=
no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:FC:B1:FB master-port=
none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=
no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:FC:B1:FC master-port=
none mtu=1500 name=ether3 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=
no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:FC:B1:FD master-port=
none mtu=1500 name=ether4 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=
no full-duplex=yes l2mtu=1598 mac-address=00:0C:42:FC:B1:FE master-port=
none mtu=1500 name=ether5 speed=100Mbps
/interface ethernet switch
set 0 mirror-source=none mirror-target=none name=switch1
set [ find default=yes ] authentication-types="" eap-methods=passthrough
group-ciphers=aes-ccm group-key-update=5m interim-update=0s
management-protection=disabled management-protection-key="" mode=none name=
default radius-eap-accounting=no radius-mac-accounting=no
radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=
XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none
static-algo-1=none static-algo-2=none static-algo-3=none static-key-0=""
static-key-1="" static-key-2="" static-key-3="" static-sta-private-algo=
none static-sta-private-key="" static-transmit-key=key-0
supplicant-identity=MikroTik tls-certificate=none tls-mode=no-certificates
unicast-ciphers=aes-ccm wpa-pre-shared-key="" wpa2-pre-shared-key=""
/interface wireless
set 0 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0
antenna-mode=ant-a area="" arp=enabled band=2ghz-b/g/n basic-rates-a/g=
6Mbps basic-rates-b=1Mbps bridge-mode=enabled channel-width=20mhz
compression=no country=no_country_set default-ap-tx-limit=0
default-authentication=yes default-client-tx-limit=0 default-forwarding=yes
dfs-mode=none disable-running-check=no disabled=no disconnect-timeout=3s
distance=dynamic frame-lifetime=0 frequency=2412 frequency-mode=
manual-txpower frequency-offset=0 hide-ssid=no ht-ampdu-priorities=0
ht-amsdu-limit=8192 ht-amsdu-threshold=8192 ht-basic-mcs=
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-guard-interval=any
ht-rxchains=0 ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mc
s-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-
18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" ht-txchains=0
hw-fragmentation-threshold=disabled hw-protection-mode=none
hw-protection-threshold=0 hw-retries=7 l2mtu=2290 mac-address=
00:0C:42:FC:B1:FF max-station-count=2007 mode=ap-bridge mtu=1500
multicast-helper=default name=wlan1 noise-floor-threshold=default
nv2-cell-radius=30 nv2-noise-floor-offset=default nv2-preshared-key=""
nv2-qos=default nv2-queue-count=2 nv2-security=disabled on-fail-retry-time=
100ms periodic-calibration=default periodic-calibration-interval=60
preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=
000C42FCB1FF rate-selection=advanced rate-set=default scan-list=default
security-profile=default ssid=TECHNOPLUS station-bridge-clone-mac=
00:00:00:00:00:00 supported-rates-a/g=
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=
1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-power-mode=default
update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=
none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled
wireless-protocol=any wmm-support=disabled
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbp
s:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:17,H
T20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,HT40-0:
17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-7:17"
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=
3200 framer-policy=none
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=
hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=
cookie,http-chap name=default rate-limit="" smtp-server=0.0.0.0
split-user-domain=no use-radius=no
add dns-name=logout.biz hotspot-address=172.168.20.1 html-directory=hotspot
http-proxy=0.0.0.0:0 login-by=mac,http-chap,https,http-pap
mac-auth-password="" name=hsprof1 nas-port-type=wireless-802.11
radius-accounting=yes radius-default-domain="" radius-interim-update=
received radius-location-id="" radius-location-name="" radius-mac-format=
XX:XX:XX:XX:XX:XX rate-limit="" smtp-server=0.0.0.0 split-user-domain=no
ssl-certificate=none use-radius=yes
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m name=default
shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=3des
lifetime=30m name=default pfs-group=modp1024
add name=dhcp_pool1 ranges=172.168.20.2-172.168.20.254
add address-pool=dhcp_pool1 authoritative=after-2sec-delay bootp-support=static
disabled=no interface=bridge1 lease-time=1d name=dhcp1
/ip hotspot
add address-pool=dhcp_pool1 addresses-per-mac=1 disabled=no idle-timeout=5m
interface=bridge1 keepalive-timeout=none name=hotspot1 profile=hsprof1
add address-pool=dhcp_pool1 advertise=no idle-timeout=none keepalive-timeout=2m
name=64k/128k open-status-page=always rate-limit=64k/128k shared-users=1
status-autorefresh=1m transparent-proxy=yes
name=98k/128k open-status-page=always rate-limit=98k/128k shared-users=1
name=128k/128k open-status-page=always rate-limit=128k/128k shared-users=1
/port
set 0 baud-rate=9600 data-bits=8 flow-control=none name=usb1 parity=none
stop-bits=1
/ppp profile
set 0 change-tcp-mss=yes name=default only-one=default remote-ipv6-prefix-pool=
none use-compression=default use-encryption=default use-ipv6=yes use-mpls=
default use-vj-compression=default
set 1 change-tcp-mss=yes name=default-encryption only-one=default
remote-ipv6-prefix-pool=none use-compression=default use-encryption=yes
use-ipv6=yes use-mpls=default use-vj-compression=default
/interface ppp-client
add add-default-route=yes allow=pap,chap,mschap1,mschap2 apn=
web.gprs.mtnnigeria.net data-channel=0 dial-command=ATDT dial-on-demand=no
disabled=no info-channel=0 keepalive-timeout=30 max-mru=1500 max-mtu=1500
modem-init="" mrru=disabled name=ppp-out1 null-modem=no password="" phone=
"" pin="" port=usb1 profile=default use-peer-dns=yes user=""
internet.ng.zain.com data-channel=0 dial-command=ATDT dial-on-demand=yes
modem-init="" mrru=disabled name=ppp-out2 null-modem=no password="" phone=
"" pin="" profile=default use-peer-dns=yes user=""
internet.ng.zain.com data-channel=0 dial-command=ATDT dial-on-demand=no
disabled=no info-channel=3 keepalive-timeout=30 max-mru=1500 max-mtu=1500
modem-init="" mrru=disabled name=ppp-out3 null-modem=no password="" phone=
add add-default-route=yes allow=pap,chap,mschap1,mschap2 apn=internet
data-channel=0 dial-command=ATDT dial-on-demand=yes disabled=yes
info-channel=0 keepalive-timeout=30 max-mru=1500 max-mtu=1500 modem-init=""
mrru=disabled name=ppp-out4 null-modem=no password="" phone="" pin="" port=
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20
red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=none name=only-hardware-queue
set 6 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 7 kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no
ignore-as-path-len=no name=default out-filter="" redistribute-connected=no
redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no
redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never in-filter=ospf-in
metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=auto
metric-rip=20 metric-static=20 name=default out-filter=ospf-out
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no
redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=
backbone type=default
/routing ospf-v3 instance
set [ find default=yes ] disabled=no distribute-default=never metric-bgp=auto
metric-connected=20 metric-default=1 metric-other-ospf=auto metric-rip=20
metric-static=20 name=default redistribute-bgp=no redistribute-connected=no
redistribute-other-ospf=no redistribute-rip=no redistribute-static=no
router-id=0.0.0.0
/routing ospf-v3 area
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0 authentication-password=""
authentication-protocol=MD5 encryption-password="" encryption-protocol=DES
name=public read-access=yes security=none write-access=no
/system logging action
set 0 memory-lines=100 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=100
disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote=:: remote-port=514 src-address=0.0.0.0
syslog-facility=daemon syslog-severity=auto target=remote
/tool user-manager customer
add backup-allowed=yes disabled=no login=admin password=""
paypal-accept-pending=no paypal-allowed=no paypal-secure-response=no
permissions=owner signup-allowed=no time-zone=-00:00
/tool user-manager profile
add name=30mins name-for-users="" override-shared-users=off owner=admin price=
100 starts-at=logon validity=1d
add name=1hour name-for-users="" override-shared-users=off owner=admin price=
150 starts-at=logon validity=2d
add name=2hours name-for-users="" override-shared-users=off owner=admin price=
250 starts-at=logon validity=4d
add name=10mins name-for-users="" override-shared-users=off owner=admin price=
/tool user-manager profile limitation
add address-list="" download-limit=0B group-name="" ip-pool="" name=30mins
rate-limit-min-rx=131072B rate-limit-min-tx=131072B rate-limit-rx=131072B
rate-limit-tx=131072B transfer-limit=0B upload-limit=0B uptime-limit=30m
add address-list="" download-limit=0B group-name="" ip-pool="" name=1hour
transfer-limit=0B upload-limit=0B uptime-limit=1h
add address-list="" download-limit=0B group-name="" ip-pool="" name=2hours
rate-limit-min-rx=131072B rate-limit-min-tx=131072B rate-limit-rx=262144B
rate-limit-tx=262144B transfer-limit=0B upload-limit=0B uptime-limit=2h
add address-list="" download-limit=0B group-name="" ip-pool="" name=10mins
rate-limit-tx=131072B transfer-limit=0B upload-limit=0B uptime-limit=10m
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,web
,sniff,sensitive,api,!ftp,!write,!policy" skin=default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pass
word,web,sniff,sensitive,api,!ftp,!policy" skin=default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,wi
nbox,password,web,sniff,sensitive,api" skin=default
add bridge=bridge1 disabled=no edge=auto external-fdb=auto horizon=none
interface=ether1 path-cost=10 point-to-point=auto priority=0x80
interface=ether2 path-cost=10 point-to-point=auto priority=0x80
interface=ether3 path-cost=10 point-to-point=auto priority=0x80
interface=ether4 path-cost=10 point-to-point=auto priority=0x80
interface=wlan1 path-cost=10 point-to-point=auto priority=0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
set 0 vlan-header=leave-as-is vlan-mode=disabled
set 1 vlan-header=leave-as-is vlan-mode=disabled
set 2 vlan-header=leave-as-is vlan-mode=disabled
set 3 vlan-header=leave-as-is vlan-mode=disabled
set 4 vlan-header=leave-as-is vlan-mode=disabled
set 5 vlan-header=leave-as-is vlan-mode=disabled
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=
default enabled=no keepalive-timeout=60 mac-address=FE:B9:81:F7:75:64
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=
default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=
disabled port=443 verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no
streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.100.1/24 disabled=no interface=ether5 network=192.168.100.0
add address=172.168.20.1/24 disabled=no interface=bridge1 network=172.168.20.0
/ip dhcp-server config
set store-leases-disk=5m
add address=172.168.20.0/24 dhcp-option="" dns-server=
4.2.2.2,8.8.8.8,205.171.3.65 gateway=172.168.20.1 ntp-server=""
wins-server=""
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB
max-udp-packet-size=4096 servers=10.109.5.97,10.199.212.120
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=
10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s
tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s
udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here"
disabled=yes
disabled=yes to-addresses=0.0.0.0
add action=masquerade chain=srcnat disabled=no src-address=172.168.20.0/24
add action=masquerade chain=srcnat comment="masquerade hotspot network"
disabled=no src-address=172.168.20.0/24 to-addresses=0.0.0.0
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot service-port
/ip hotspot user
add disabled=no name=admin password=faith profile=default
add disabled=no name=sister password=mabu profile=default server=hotspot1
add disabled=no limit-uptime=5d9h name=inno password=web profile=128k/128k
server=hotspot1
add disabled=no limit-uptime=1h name=obinna password=uchenna profile=default
add disabled=no limit-uptime=1h name=fun password=obi profile=128k/128k server=
hotspot1
add disabled=no limit-uptime=1h name=ada password=owerri profile=128k/128k
add disabled=no limit-uptime=30m name=30 password=30 profile=128k/128k server=
hotspot1
add disabled=no limit-uptime=30m name=35 password=35 profile=128k/128k server=
hotspot1
add disabled=no limit-uptime=2w1d name=tect password=ademola profile=128k/128k
server=hotspot1
add disabled=no limit-uptime=1h name=subject password=332 profile=128k/128k
server=hotspot1
add disabled=no limit-uptime=1h name=name password=104 profile=128k/128k
server=hotspot1
add disabled=no limit-uptime=1h name=course password=530 profile=128k/128k
server=hotspot1
add disabled=no limit-uptime=1h name=take password=110 profile=128k/128k
server=hotspot1
/ip neighbor discovery
set ether1 disabled=no
set ether2 disabled=no
set ether3 disabled=no
set ether4 disabled=no
set ether5 disabled=no
set wlan1 disabled=yes
set bridge1 disabled=no
set ppp-out1 disabled=yes
set ppp-out2 disabled=yes
set ppp-out3 disabled=yes
set ppp-out4 disabled=yes
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4
cache-on-disk=no enabled=no max-cache-size=none max-client-connections=600
max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0
parent-proxy-port=0 port=8080 serialize-connections=no src-address=0.0.0.0
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=no port=21
set www address="" disabled=no port=80
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=yes port=443
set api address="" disabled=yes port=8728
set winbox address="" disabled=no port=8291
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=
all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/pub disabled=no
max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest password="" read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no inactive-flow-timeout=
15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/ipv6 nd
set [ find default=yes ] advertise-dns=no advertise-mac-address=yes disabled=no
hop-limit=unspecified interface=all managed-address-configuration=no mtu=
unspecified other-configuration=no ra-delay=3s ra-interval=3m20s-10m
ra-lifetime=30m reachable-time=unspecified retransmit-interval=unspecified
/ipv6 nd prefix default
set autonomous=yes preferred-lifetime=1w valid-lifetime=4w2d
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0
use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1 queue=only-hardware-queue
set ether2 queue=only-hardware-queue
set ether3 queue=only-hardware-queue
set ether4 queue=only-hardware-queue
set ether5 queue=only-hardware-queue
set wlan1 queue=wireless-default
/radius
add accounting-backup=no accounting-port=1813 address=127.0.0.1
authentication-port=1812 called-id="" disabled=no domain="" realm=""
secret=123456 service=hotspot timeout=300ms
/radius incoming
set accept=yes port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s
multiplier=5
/routing igmp-proxy
set query-interval=2m5s query-response-interval=10s quick-leave=no
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m
gateway-selection=no-gateway origination-interval=5s preferred-gateway=
0.0.0.0 timeout=1m ttl=50
/routing pim
set switch-to-spt=yes switch-to-spt-bytes=0 switch-to-spt-interval=1m40s
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no
redistribute-connected=no redistribute-ospf=no redistribute-static=no
routing-table=main timeout-timer=3m update-timer=30s
/routing ripng
/snmp
set contact="" enabled=no engine-id="" location="" trap-generators=""
trap-target="" trap-version=1
/system clock
set time-zone-name=Africa/Lagos
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=
"jan/01/1970 00:00:00" time-zone=+00:00
/system gps
set channel=0 enabled=no set-system-time=no
/system identity
set name="technoplus cafe"
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set ppp-out4 disabled=yes display-time=5s
set ppp-out3 disabled=yes display-time=5s
set ppp-out2 disabled=yes display-time=5s
set ppp-out1 disabled=yes display-time=5s
set bridge1 disabled=yes display-time=5s
set wlan1 disabled=yes display-time=5s
set ether5 disabled=yes display-time=5s
set ether4 disabled=yes display-time=5s
set ether3 disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
set ether1 disabled=yes display-time=5s
/system leds
set 0 disabled=no interface=wlan1 leds=wlan-led type=wireless-status
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=yes mode=unicast primary-ntp=41.216.193.26 secondary-ntp=196.25.1.9
/system ntp server
set broadcast=no broadcast-addresses="" enabled=no manycast=yes multicast=no
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
/system routerboard settings
set boot-device=nand-if-fail-then-ethernet boot-protocol=bootp cpu-frequency=
400MHz force-backup-booter=no silent-boot=no
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=
0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=100
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 starttls=no user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=1000KiB file-name="" filter-ip-address="" filter-ip-protocol=""
filter-mac-address="" filter-mac-protocol="" filter-port="" filter-stream=
yes interface=all memory-limit=100KiB memory-scroll=yes only-headers=no
streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/tool user-manager profile profile-limitation
add from-time=0s limitation=30mins profile=30mins till-time=23h59m59s weekdays=
sunday,monday,tuesday,wednesday,thursday,friday,saturday
add from-time=0s limitation=1hour profile=1hour till-time=23h59m59s weekdays=
add from-time=0s limitation=2hours profile=2hours till-time=23h59m59s weekdays=
add from-time=5h limitation=10mins profile=10mins till-time=23h59m59s weekdays=
add from-time=5h profile=10mins till-time=23h59m59s weekdays=
add from-time=0s limitation=10mins profile=10mins till-time=23h59m59s weekdays=
/tool user-manager router
add coa-port=1700 customer=admin disabled=no ip-address=127.0.0.1 log="" name=
hotspot shared-secret=123456 use-coa=no
/tool user-manager user
add customer=admin disabled=no name=test3 password=test3 shared-users=1
wireless-enc-algo=none wireless-enc-key="" wireless-psk=""
add customer=admin disabled=no name=demola password=ademola shared-users=1
add customer=admin disabled=no name=30yrabnu password=k79egy shared-users=1
add customer=admin disabled=no name=30byhzm6 password=zynahg shared-users=1
add customer=admin disabled=no name=30695wi2 password=hwvxqa shared-users=1
add customer=admin disabled=no name=309xe53k password=vv3t85 shared-users=1
add customer=admin disabled=no name=30uzrcva password=dx3zvw shared-users=1
add customer=admin disabled=no name=30vxzsq3 password=cpjcyh shared-users=1
add customer=admin disabled=no name=309rgzpd password=7z3e53 shared-users=1
add customer=admin disabled=no name=1h7tzvfm password=2y9k shared-users=1
add customer=admin disabled=no name=1h8bdca9 password=mmhk shared-users=1
add customer=admin disabled=no name=1h2mmjzy password=rhn4 shared-users=1
add customer=admin disabled=no name=1hnhn8ea password=8caf shared-users=1
add customer=admin disabled=no name=1h95s672 password=zv6h shared-users=1
add customer=admin disabled=no name=1hbae23g password=ax35 shared-users=1
add customer=admin disabled=no name=1huu22gd password=72xq shared-users=1
add customer=admin disabled=no name=1hvsgjv9 password=ew36 shared-users=1
add customer=admin disabled=no name=1h29zbhz password=2h5e shared-users=1
add customer=admin disabled=no name=1h9ns43a password=beqp shared-users=1
add customer=admin disabled=no name=1hf2n4fe password=85b2 shared-users=1
add customer=admin disabled=no name=1hdpec2p password=5v53 shared-users=1
add customer=admin disabled=no name=1hpmjxp5 password=h2e2 shared-users=1
add customer=admin disabled=no name=ade password=ade shared-users=1
add customer=admin disabled=no name=10mins password=10mins shared-users=1
add customer=admin disabled=no name=30psbb password=uf25 shared-users=1
add customer=admin disabled=no name=30ucwv password=77yi shared-users=1
add customer=admin disabled=no name=30w3n9 password=pw5h shared-users=1
add customer=admin disabled=no name=30k5x4 password=ssb7 shared-users=1
add customer=admin disabled=no name=30bkig password=qff3 shared-users=1
add customer=admin disabled=no name=30i2ky password=v2fd shared-users=1
add customer=admin disabled=no name=30tawz password=dmbf shared-users=1
add customer=admin disabled=no name=30wrrm password=v8us shared-users=1
add customer=admin disabled=no name=30778b password=csfe shared-users=1
add customer=admin disabled=no name=3096q6 password=issj shared-users=1
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s
use-radius=no
Your help will be appreciated, if anyone has such problem, let him/her help.
Use a UPS. A router should never be installed on unstable power.
