I recently re-modified the ‘hotspot ’ html documents .. in advance of the modifications I have just completed, unauthorized users were successfully redirected to the login screen..
After the html doc updates and FTP ’ing the files to the router hotspot dir , unauthorized users are no longer redirected to the login screen (short of typing in the hotspot IP address which then displays the login screen and does allow successful logons - but is nonetheless incorrect -. )
I have reverified the layout of the code in each html doc.
I have re-uploaded the default html docs to the router and still the same result - no login screen display -
I have reset the router configuration four times and reconfigured the hotspot … I used the auto configuration as exhibited here: https://wiki.mikrotik.com/wiki/Manual:IP/Hotspot ; as I have also followed this example: https://mikrotik.com/documentation/manual_2.7/IP/Hotspot.html#ht90237610 (which I prefer configuration-wise ).
Has anyone encountered this same problem? Or maybe you see my error(s), I would appreciate any suggestions.
# jan/02/1970 15:09:01 by RouterOS 6.42.3
# software id = 046D-LZ6N
# model = 333
# serial number = 179801C18694
/interface wireless
set [ find default-name=wlan1 ] antenna-mode=ant-b country="united states" disabled=no mode=ap-bridge radio-name=5ghz-hs-interface ssid="wubble"
set [ find default-name=wlan2 ] antenna-mode=ant-b country="united states" disabled=no mode=ap-bridge radio-name=2ghz-hs-interface ssid="gubble"
/ip hotspot profile
add hotspot-address=192.188.254.254 login-by=cookie,http-chap,trial name=hs-server-profile-2ghz
add comment=pre-auth-pool-2ghz name=pool0 ranges=192.188.254.10-192.188.254.252
add comment=post-auth-pool-2ghz name=pool1 ranges=172.168.254.10-192.168.254.252
add add-arp=yes address-pool=pool0 disabled=no interface=wlan2 lease-time=14s name=hs-dhcp-server-2ghz src-address=192.188.254.254
/ip hotspot
add address-pool=pool1 disabled=no idle-timeout=none interface=wlan2 name=hs-server-2ghz profile=hs-server-profile-2ghz
add address=192.168.254.2/24 comment=wan interface=ether1 network=192.168.254.0
add address=192.188.254.254/24 comment=pre-auth-network-2ghz interface=wlan2 network=192.188.254.0
add address=172.168.254.254/24 comment=post-auth-network-2ghz interface=wlan2 network=172.168.254.0
add address=192.188.254.254/32 dns-server=8.8.8.8,192.168.254.2 gateway=192.168.254.254 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add action=accept chain=hs-pre-auth comment="limit unauthorized hotspot clients" disabled=yes
add action=jump chain=forward comment="limit access for unauthorized hotspot clients" disabled=yes jump-target=hs-pre-auth src-address=192.188.254.0/24
add action=accept chain=hs-input comment="accept requests for hotspot servlet (port 80)" disabled=yes protocol=tcp src-address=192.188.254.0/24
add action=accept chain=hs-input comment="accept requests for hotspot servlet (port 443)" disabled=yes dst-port=443 protocol=tcp src-address=192.188.254.0/24
add action=accept chain=hs-input comment="accept requests from local dhcp server" disabled=yes dst-port=67 protocol=udp src-address=192.188.254.0/24
add action=jump chain=hs-input comment="limit access for unauthorized hotspot clients" disabled=yes jump-target=hs-pre-auth
add action=return chain=hs-pre-auth comment="allow ping requests" disabled=yes protocol=icmp
add action=return chain=hs-pre-auth comment="allow dns requests" disabled=yes dst-port=53 protocol=udp
add action=reject chain=hs-pre-auth comment="reject access for unauthorized hotspot clients" disabled=yes reject-with=icmp-network-unreachable
add action=accept chain=hotspot comment="account authorized hotspot clients" disabled=yes
add action=jump chain=forward comment="account traffic for authorized hotspot clients" disabled=yes jump-target=hotspot
add action=masquerade chain=srcnat comment="masquerade hotspot pre-auth network" src-address=192.188.254.0/24
add action=redirect chain=dstnat comment="redirect pre-auth hotspot clients to hotspot service (port 80)" dst-port=80 protocol=tcp src-address=\
192.188.254.0/24 to-ports=80
add action=redirect chain=dstnat comment="redirect pre-auth hotspot clients to hotspot service (port 443)" dst-port=443 protocol=tcp src-address=\
/ip hotspot user
add name=ganja password=1234
/ip hotspot walled-garden
add comment="place hotspot rules here"
/ip hotspot walled-garden ip
add action=accept disabled=no !dst-address !dst-address-list !dst-port !protocol server=hs-server-2ghz !src-address !src-address-list
add distance=1 gateway=192.168.254.254
add distance=1 dst-address=192.168.254.13/32 gateway=ether1
add distance=1 dst-address=192.168.254.254/32 gateway=ether1
/system identity
set name=nas-1
/system routerboard settings
set cpu-frequency=333MHz
2frogs
June 26, 2018, 5:36pm
2
There are several errors!
192.188.254.254 instead of 192.168.254.254..
No DNS under IP>DNS, all DNS request get redirected to the Mikrotik.
DHCP lease-time needs to be in a number of hours or some devices (Apple) will not work.
Set ip-pool=none in IP>Hotspot, devices will get IP Address from DHCP Server.
That should get you started.
Thank you for the informative reply 2frogs.
I changed the DCHP Server network from the 192.168.254x → 192.188.254x (late nights worked negatively against my vision )
added the dns numbers 8.8.8.8, 192.188.254.254 (I incorrectly assumed that the auto hotspot configuration would set those )
the DHCP lease time has been set to 12H
and in the hotspot I disabled the DHCP.
Unfortunately, I still get the identical results [><], no log-in screen and the device browser works for a long while before returning “server not found”
# jan/02/1970 18:58:15 by RouterOS 6.42.3
# model = 333
/interface wireless
/ip hotspot profile
/ip hotspot
add disabled=no idle-timeout=none interface=wlan2 name=hs-server-2ghz profile=hs-server-profile-2ghz
add add-arp=yes address-pool=pool0 disabled=no interface=wlan2 lease-time=12h name=hs-dhcp-server-2ghz src-address=192.188.254.254
add address=192.188.254.254/32 dns-server=8.8.8.8,192.188.254.254 gateway=192.188.254.254 netmask=24 ntp-server=128.138.140.44,128.138.141.172
set allow-remote-requests=yes servers=8.8.8.8,192.188.254.254
/ip dns static
add address=192.188.254.254 name=router
add action=jump chain=forward comment="limit access for unauthorized hotspot clients" jump-target=hs-pre-auth src-address=192.188.254.0/24
add action=accept chain=input comment="accept requests for hotspot servlet (port 80)" protocol=tcp src-address=192.188.254.0/24
add action=accept chain=input comment="accept requests for hotspot servlet (port 443)" dst-port=443 protocol=tcp src-address=192.188.254.0/24
add action=accept chain=input comment="accept requests from local dhcp server" dst-port=67 protocol=udp src-address=192.188.254.0/24
add action=jump chain=input comment="limit access for unauthorized hotspot clients" jump-target=hs-pre-auth
add action=return chain=hs-pre-auth comment="allow ping requests" protocol=icmp
add action=return chain=hs-pre-auth comment="allow dns requests" dst-port=53 protocol=udp
add action=reject chain=hs-pre-auth comment="reject access for unauthorized hotspot clients" reject-with=icmp-network-unreachable
add action=jump chain=forward comment="account traffic for authorized hotspot clients" jump-target=hotspot
192.188.254.0/24 to-ports=443
/ip hotspot user
add name=ptaylor password=1234
/ip service
set www port=8080
set www-ssl disabled=no
/system identity
set name=nas-1
Thank you
2frogs
June 26, 2018, 8:27pm
4
Can the Mikrotik resolve DNS properly? Access internet?
Use /tools trace-route and see if it trace to google.com with “use dns” checked.
Thank you 2frogs.
Yes, the router sees the Internet _ _ _ I am able to trace-route using DNS to google.com (however there are 2 time-outs near the end).
Likewise, the mt manual page loads while inside of the router gui.
DHCP server return to client device:
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Qualcomm Atheros AR9485 Wireless Network Adapter
Physical Address. . . . . . . . . : 28-C2-DD-91-C5-D9
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::b596:c198:1e11:e682%17(Preferred)
IPv4 Address. . . . . . . . . . . : 192.188.254.251(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Lease Obtained. . . . . . . . . . : Monday, June 25, 2018 8:41:10 PM
Lease Expires . . . . . . . . . . : Wednesday, June 27, 2018 2:47:56 AM
Default Gateway . . . . . . . . . :
DHCP Server . . . . . . . . . . . : 192.188.254.254
DHCPv6 IAID . . . . . . . . . . . : 136889053
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1D-7C-25-49-30-5A-3A-87-75-EB
DNS Servers . . . . . . . . . . . : 192.188.254.254
NetBIOS over Tcpip. . . . . . . . : Enabled
From client device if a ping is sent to → 192.188.254.254 yields no returns
Thank you 2 frogs
R1CH
June 28, 2018, 11:58am
6
Haven’t used hotspot before, but this certainly doesn’t look right:
You probably want a /24 network at least?
Just this morning I elected to replace the routerboard entirely _ _ _ problem solved!
Much thanks to 2frogs and yourself for taking the time to help.
Have a great day.
Keep your shiny side UP!
Life is 10% what happens and 90% how you respond to it happening.
