Users Quota/Speed Limit
Dear Sirs,
I just bought the RB751 for testing and if all is well the plan is to setup multiple routerOS on an ESXi server for my company, now i have already setup 4 WAN Bonding and Web Proxy Caching, which was extremely successful. But what i really need if possible, to setup DHCP with reservation for each machine (thats 50), then create profiles (3) each with Traffic/Speed limitation, and assign it to each of users, no authenticating need, just users would connect through combination of correct ip and mac, all other users not available in the database are prohibited from using the internet. now there is a already a software i am using that does all of this its called “Usergate Firewall and Proxy”, but i really want to move to Mikrotik, for the more advanced features
Best Regards
This is a BASIC overview of how to do it. You will need the Wiki to fill in the details. Feel free to reply if you are having trouble.
After setting up your DHCP address reservations you need to create address lists in the firewall. Create your 3 lists as well as the fourth list that has no access.
Based on the address lists establish packet and routing marks. Packet marks for Queue Tree and routing marks for black-holing the disallowed users.
Setup your queue tree based on the Wiki and you may need this for quotas http://forum.mikrotik.com//viewtopic.php?t=308
Also make sure you had your black-hole routes to the routing table based on the routing mark.
Check List
  1. DHCP Reservations based on MAC [Ip DHCP Server]
  2. Address lists [IP Firewall]
  3. Packet marks (for queue) [IP Firewall]
  4. Routing Marks (for disallowed users) [IP Firewall]
  5. Queue Tree (for speed limit uses Packet Marks) [Queue]
  6. Route for black hole traffic (Uses routing marks) [IP Routes]
