Hi all,
is there any body know how many users can connect on the router board 750gl & Rb 1100 Hotspot i mean the maximum users that devices support
Hi all,
That is a loaded question. What exactly are you doing? Any QoS, VPNs, etc?
Load Balancing 4 ports using PCC, then i installed hotsopt with authentication
How much bandwidth is each of your connections?
For a setup like that I wouldn’t consider using the 750. At a minimum I would use a 2011.
Both the 750 and the 1100 use the same OS, so no differantance in settings and ablity’s.
The total amount of users depends on what license level you have.
With a level 4 you can have a total of 200 users but only 20 of these users can be thru hotspot.
With a level 5 you can have 500 total but only 50 hotspot.
With a level 6 it is unlimited both total and hotspot, which means you have 400 users and out of the 400, 350 are using hotspot.
These totals are for users on the system at the same time.
