Using 1 wapac. Set to cap or dual ap better?
Bro which setting is the best?
The best solution is the one that suits you.
It really depends. If it’s “just” a small apartment and the AP is used for home use, nothing is speaking against setting it up as dedicated AP.
Labor-wise, setting it up as CAP it would be pretty much the same.
If you need scalability, either AP- and/or SSID-wise, going for CAP is surely better.
Be aware that CAPsMANaged networks do not support MTik’s proprietary extenions, so just adding another MTik devica in station-bridge mode to hook up regular wired devices to the existingg WiFi does not work.
-Chris
thanks bro reply!!
1.i saw so many function using cap mode is can not use…EXAMPLE CAP SCANNER
2.cap mode …vap don’t know how to config…
Well, there is a couple of features “missing” in CAPsMAN, but no real show stopper. CAPsMAN works great for its purpose.
Adding vaps is as simple as creating a new configuration and adding it as slave configuration in the provisioning entry.
-Chris
