Using 2ghz-10mhz mode
I’m trying to over come some interference issues by using 2ghz-10mhz option. I’m running wrap board with CM9 and using pacwireless antennas. When i choose 2ghz-10mhz or 5mhz mode my wireless scan shows nothing at all. Go back to 2.4GhzB/G and everything on the scan list comes back.
Do i need to use any special antennas to take advantage of that mode ? Or any license issues with Router os like when i use L4 licence i can’t implement that 2ghz-10mhz stuff ? Or any other ideas that you experienced?
My antenna is Pacwireless PAWVA24-16 Vagi 2.4Ghz which is said to support 2.4GHz to 2.483GHz 802.11 applications on their web site.
http://www.pacwireless.com/products/vagi_series.shtml
Gokalp
both sides of the link must be set to 10mhz mode (and thus both sides of the link must be mikrotik devices)
On the routers scan list i put the configured frequency and it worked. Thanks to Mikrotik support.
interface wireless set wlan1 scan-list=default,configured_frequency
Gokalp
Router os 2.9.30
