I work in a production department, we program Teltonika RUT routers to a standardized configuration to be delivered to venues. We currently program each unit individually on 192.168.1.1.
I have purchased a hEX S, I want the ability to have 3 Teltonika routers connected directly to the hEX S and i want to be able to connect via my workstation, to each router individually on their factory IP 192.18.1.1 so i can program them at the same time, being able to work on 3 routers are the same time will increase my output of standardized routers.
I’ve managed to work through connecting 1 router using port 8001 on ether3 (192.168.88.1:8001), but ether4 and ether5 (8002 and 8803, respectivly) don’t load the webui of the Teltonika Routers.
I’ve put my config below, but I cannot figure out at what step this is going wrong.
add admin-mac= auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/routing table
add fib name=to-ether3
add fib name=to-ether4
add fib name=to-ether5
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=sfp1
/interface bridge settings
set use-ip-firewall=yes
192.168.88.0
add address=192.168.1.2/24 comment="To Teltonika #1" interface=ether3 \
network=192.168.1.0
add address=192.168.2.2/24 comment="To Teltonika #2" interface=ether4 \
network=192.168.2.0
add address=192.168.3.2/24 comment="To Teltonika #3" interface=ether5 \
network=192.168.3.0
/ip dhcp-client
# Interface not active
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip firewall mangle
add action=mark-routing chain=prerouting dst-address=192.168.88.1 dst-port=\
8001 new-routing-mark=to-ether3 protocol=tcp
8002 new-routing-mark=to-ether4 protocol=tcp
8003 new-routing-mark=to-ether5 protocol=tcp
add action=masquerade chain=srcnat comment="NAT to Teltonika 1" \
out-interface=ether3
add action=masquerade chain=srcnat comment="NAT to Teltonika 2" \
out-interface=ether4
add action=masquerade chain=srcnat comment="NAT to Teltonika 3" \
out-interface=ether5
add action=dst-nat chain=dstnat comment="Teltonika 1 Web" dst-address=\
192.168.88.1 dst-port=8001 protocol=tcp to-addresses=192.168.1.1 \
to-ports=80
add action=dst-nat chain=dstnat comment="Teltonika 2 Web" dst-address=\
192.168.88.1 dst-port=8002 protocol=tcp to-addresses=192.168.2.1 \
to-ports=80
add action=dst-nat chain=dstnat comment="Teltonika 3 Web" dst-address=\
192.168.88.1 dst-port=8003 protocol=tcp to-addresses=192.168.3.1 \
to-ports=80
add comment="Route to Teltonika 1" disabled=no distance=1 dst-address=\
192.168.1.1/32 gateway=0.0.0.0 routing-table=to-ether3 \
suppress-hw-offload=no
add comment="Route to Teltonika 2" disabled=no distance=1 dst-address=\
192.168.1.1/32 gateway=0.0.0.0 routing-table=to-ether4 \
add comment="Route to Teltonika 3" disabled=no distance=1 dst-address=\
192.168.1.1/32 gateway=0.0.0.0 routing-table=to-ether5 \
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/routing rule
add action=lookup disabled=no routing-mark=to-ether3 table=to-ether3
add action=lookup disabled=no routing-mark=to-ether4 table=to-ether4
add action=lookup routing-mark=to-ether5 table=to-ether5
add action=lookup routing-mark=to-ether3 table=to-ether3
add action=lookup routing-mark=to-ether4 table=to-ether4
/tool mac-server
/tool mac-server mac-winbox
