Using a RouterBOARD433 and R52 for reduncancy?
Hi all,
I’m looking to set up a wifi link with redundancy in the antennas. On one side of the wifi link, one of the antennas might have its signals blocker or even get disconnected. The other side, however, is “safe”. I want to be able to send signals between these two sides that are unaffected as long as one antenna can obtain a good link.
In the office where I work I found a RouterBOARD433 and three R52 radio cards. My idea was that I could use this on the “unsafe” side and transmit signals to a pc on the “safe” side. Is it even possible the way I’m thinking? If yes, how do I set up the router board? I don’t know if I’m making myself understood, so I made a sketch:
Cheers,
Birger from Norway
So you want to use one of wireless interface while other two are working as backup right ?
Yes, but “switching” to one of the backups must happen virtually imminent. Even 100-500 ms “downtime” will hurt my system…
