Using All ports on Router at Hotspot Network
Hey guyz
How’re you doin’?
Today i have a problem again.
I have configured a rg450g.
ether1:192.168.2.1/24[wan connection]
ether2:10.0.0.1/24[HOTSPOT Network]
ether3:none
ether4:none
ether5:none
My customer want ether3,ether4 and ether5 to connect hotspot network.Probably he will add new ap’s or watch the users.
There might be a configuration that to use other 3 ports to connect hotspot network on wire.
I don’t know how to configure to activate those ports
Thanks for help
Just add the ports to the switchchip by setting their master-port to ether2.
thanks fewi saved my life :smiley:
You can also use a bridge if you want more control over what each interface does. This just takes more CPU time since a bridge uses the CPU instead of the switch chip.
