Using an ADSL router as modem only.
I’m trying to get my HG533 router working in bridge mode as a modem only. It is able to get an ADSL session up.
I set up the MikroTik more or less as described here:
http://robert.penz.name/484/howto-use-a-mikrotik-as-router-for-a-pppoa-dsl-internet-connection/
Except I did not do the full reset at the start. I just set up a ppp profile, then ppp client as described. I also tried a PPPoE client, with the first ethernet port as the target. I am actually not sure if I should be using a ppp client, a PPPTP client or a PPPoE client.
PPPoE client logs:
11:20:07 pppoe,ppp,info pppoe-out1: initializing…
11:20:07 pppoe,ppp,info pppoe-out1: connecting…
11:20:17 pppoe,ppp,info pppoe-out1: terminating… - disconnected
11:20:17 pppoe,ppp,info pppoe-out1: disconnected
ppp client logs:
11:08:38 pptp,ppp,info ppptpDslInternet: connecting…
11:08:38 pptp,ppp,info ppptpDslInternet: terminating… - connection refused
11:08:38 pptp,ppp,info ppptpDslInternet: disconnected
Any pointers to how I can figure out why this doesn’t work?
The example you linked says the Mikrotik would talk PPTP to the modem.
What are the specs of your DSL connection?
Use PPPoE
There are some modems that require PPTP but those aren’t the norm, and if yours is such a modem, it will tell you that you need to do a PPPoA connection… PPtP just happens to work with it. “Connection refused” means the device isn’t doing PPtP…
Are you sure that your username and password are correct?
