Using breakout DAC on CRS804
Hello, I'm considering using a DDQ 400 Gbps switch to connect a cluster of 4 to 8 Nvidia Jetson AGX Thor nodes along with 4 Nvidia DGX Spark nodes.
Regarding the 4 DGX Spark nodes (2x 200 Gbps ports), using QSFP56-DD 400G to 2x QSFP56 200G breakout DAC cables can do.
Regarding the 4 Jetson AGX Thor nodes (1x QSFP28 port supporting only 4x 25Gbps or 4x 10Gbps interfaces, no 100Gbps interface), could I use a QSFP56-DD to 4x QSFP28 breakout DAC cable and configure RouterOS on the CRS804 to split the 400G port into 16x 25Gbps interfaces (or 16x 10Gbps)?
Thx
The limit here is the number of lanes, rather than simply dividing 400G by 25G. Each QSFP56-DD port on the CRS804 has eight lanes. The documented breakout modes include 8×25G and 8×10G, not 16×25G or 16×10G from one port.
A passive breakout DAC maps the available lanes; it does not create another eight. If you need four separate 25G links for each of four Thor nodes, that is sixteen 25G lanes, so one eight-lane port is insufficient for that arrangement.
Also check the exact cable's lane mapping at every QSFP28 end. A cable described as “400G to 4×100G” does not by itself establish that each remote connector supplies four independent 25G links. The endpoint's supported electrical interface and breakout mode must match as well.
The manual specifies forced speed with auto-negotiation disabled for these breakout modes. Before choosing a cable, I would map the required endpoint lanes against the switch's supported modes and confirm the exact cable and endpoint configuration, rather than relying on the connector shapes or aggregate bandwidth alone.
