Hi Scripting guru’s
Im populating the /interface wireless connect-list using a text file which is working great. However, if i run the script a second time, it creates duplicates in the connect-list.
Im not sure of the best way to avoid this ? Im thinking its to use the /find option to see if the mac address is already in the connect-list and skip the command if it is. However, i just cant get the format right.
Could someone shed any light on how to structure the command to check for the existance of a mac address in connect list ?
Many thanks
