Using GBIC SPF+ in CCR1036 SFP
Hello guys, this is my first post in here…
I have a problem, i have a Module GBIC SFP+ and i cant use with CCR1036 with SPF ports..
There is a incompatibility problem? Have a solution?
Thank you!
Of course you cannot use GBIC modules, because you physically cannot plug GBICs in SFP slots :slight_smile:
thank you for the quicly asnwer… but i cant use this equipment: https://www.ispshop.com.br/modulo-mini-gbic-sfp-10g-1310nm-20km-duplex-ot-8606-sf.html
On a CCR 1036?
sry, i said worng… is a MIni GBIC,
Well they state that this module is compatible with Mikrotik devices, I would suggest to contact the seller and verify if it works or not.
Or you can pick one of the modules that have been verified to work
http://wiki.mikrotik.com/wiki/Supported_Hardware#SFP_modules
Humm.. but Module SFP+ works in a SFP port?
Look on compatibility table.
http://wiki.mikrotik.com/wiki/MikroTik_SFP_module_compatibility_table
For CCR1036 SFP module can work in SFP+ slot.
Yes, SFP+ module can work in SFP slot.
