Using hAP and Metal2HSPN Together
I’ve recently purchased a hAP (RB962UIGS) and a Metal2HSPN to use to rebroadcast wifi into a RV. I want to use the Metal2HSPN to “receive” the wifi and then the hAP to re-broadcast it within the RV. I setup the metal in station mode and put it on a different private IP subnet than the hAP and basically have it working. The only problem is that I’m currently double nat’ing, and I was wondering if there was a method for blending the interfaces together, i.e. let the hAP manage the Metal2HSPN. Is there another solution for the double nat, or should I just live with it?
