I’m trying to use mangle to change the dscp value for packets bound for a certain port range, as follows:
/ip firewall mangle add action=change-dscp chain=postrouting comment=(“dscp_46_eth_port_range_1”) disabled=no protocol=udp dst-port=16400-16405 new-dscp=46
Should the above work?
Now I want to test the above to see if it works using the MikroTik packet sniffer.
But that raises a separate matter… when using the MikroTik packet sniffer with detail mode on, it displays a “TOS” field, but it appears to me that it actually displays the DSCP value there under the TOS field, which I think is not strictly accurate, because TOS and DSCP are different things stored within bit fields of the same byte, right?
There used to be a change-tos action but that doesn’t seem to exist any more.
Now back to my original attempt to change the dscp. If I use the MikroTik packet sniffer, I can see udp packets with destination ports that match the range, but their TOS value displayed is 0.
Thus the above rule doesn’t appear to work.
Any ideas?
