I need to install a WLAN services in a hotel with 11 floors (28m x 20m), a second building with 3 floors (20m x 100m).
The two building will be connected via a 5MHz bridge, or via an existing cable.
The WLan service is not meant for customers (yet), but for the internal personal using wlan for a software they use to facilitate needs in the hotel.
The idea is to have a continuous (through-going) network to be able to roam from one hotspot to another without interruption or packet loss. VoIP is NOT the goal, but an uninterrupted experiance using the software.
As we cannot use the preexisting network within the hotel we would have to rewire the hotel to connect the hotspots, and I would like to keep wiring to a minimum.
My ideas (first thoughts):
Put a switch on each floor, connect Mikrotiks via cable and set all routers on same SSID on different channels.
Put a switch on each floor, connect one Mikrotik to it and use others in a mesh on each floor.
Put a Switch on the top and bottom floor as “mesh exit points” and use Mikrotiks in mesh mode on the floors as needed. The mesh is used to transport data trough the two wired access points to the server/internet.
Use Mikrotik Wlan-Routers on each floor, connected via a 5MHz connection to replace cabling between the floors. Use other Mikrotik Routers to span the hotspot on the floors. Mikrotik’s WDS mesh solution could be used to extend the range of the wlan network on the floors and maybe between floors.
My questions:
- Is there any experiance how the Mikrotik Mesh solution works, which hardware is needed?
- What could the range of a Mikrotik be? The walls in the hotel are not concrete. The center of the hotel is steel-concrete with lifts on the inside (12x5m).
- Could I use several Wlan-cards in one box and just use extension cables for the antennas to extend the range of one Hotspot?
- Could I use one Mikrotik in the ceiling to cover two floors? Is it feasible to just install Routers every second floor?
I am very courious about your experiance, your ideas and your warnings.
Do you have any other ideas, setups or plans how to set this up?
Thanks for relpying in advance!
Robert
PS: Floor Plans
