Hello all,
A MikroTik beginner here ![]()
I have purchased a RB2011UiAS with RouterOS v6.48.4.
I have done intial configuration and made it work with the ISP’s router in normal mode.
The ISP’s router is connected to MikroTik’s LAN 1.
Everything works, it gives out IP adresses (DHCP works) and all is fine, internet works on all devices connected to MikroTik.
Now i would like to set the ISP’s router in bridge mode so that all traffic goes through MikroTik.
When I set the ISP’s router in bridge mode and don’t change any settings on MikroTik, the internet stops working.
I assume that is expected behaviour and means that the ISP’s router was really set in bridge mode and now some alterations have to be made in RouterOS?
What do I have to do in MikroTik’s configuration to restore internet functionality?
I have tried searching and googling thinking it is a pretty common question, but all I get are results about setting MikroTik in bridge mode
(it’s not the same as configuring for another router in bridge mode, is it?)
Thanks for any guidance or links to some tutorials/articles about the issue ![]()
