Using my router as two seperate units.
I have a Netscreen Firewall connected to the Internet Backbone
I’d like to use My Microtik to connect to the Internet.
I want to have Port 3 on Microtik go to The Internet, and Port 4 connect directly to the Netscreen Wan Port.
Problem is, I am already using port1 on my private network. And Port 2 uses port 1 as it’s default gateway.
Goes Like this.
Office Network 192.168.1.0/24 on Port 4… All Ip’s Nat to the same address assigned to Port 2
Problem is, how do I get the router to split in two pieces. I basically want to be able to use Port 2 as the default gateway for port 1, and Use Port 3 as the default gateway for everything else. Problem now is that I can’t get both to work as a default gateway.
Just use source routing.
You can specify what ip ranges go where.
You can only have ONE DEFAULT gateway, being uhm.. the default!
You have several options though.
  1. Use source/policy routing where you route certain “from” addresses to a certain gateway. (Eg your more expensive users are routed over your better quality/more expensive bandwidth)
  2. Loadbalance between multiple ISP’s using ECMP (I do not recommend this)
  3. Write a fail-over script for if ISP1 goes down, the default gateway will be changed to ISP2 until ISP1 is online again (there’s a few examples on the forum)
  4. Use destination routing. Here you route certain sites over X ISP. (These are usually used when a certain upstream ISP provide better speed/latency to certain sites)
Just my bit! G
