Good evening
We have a lot of public /30s in our network for simple point to point links between base stations and with the shortage of v4 beginning to bite, I wondered is there another way of using internal addressing for these links without OSPF causing issues? In the past, we have tried internal /30s between routers but had customers unable to get internet. Enabling NAT on the core routers solved this but natted everything else despite the customers being given a real IP for their endpoint.
Network segment layout is as follows
Customer router<----PPPoE----->Base station (pppsvr) <-----/30----->Base station <-----/30----->core-router<----internet---->
One idea I had was to change everything to internal addressing and set up MPLS then have a VPLS instance to each base station and run a central PPPoE concentrator in our datacenter. The problems with this setup is loss of the data-center or the concentrator would cause a 100% outage everywhere. It would also require me to take down almost the entire network to implement.
Any ideas would be grateful.
Thanks in advance
Jon
