Using queue tree's on a WDS bridge
I’m trying to use a queue tree on a WDS bridge but whenever the wireless client dis/reconnects, the queue tree parent get’s assigned to UNKNOWN and I have to go back in and manually asign it to WDS#. Actually, I don’t need queue on each individual WDS interface, I just need it on the wlan2 interface as a whole, however I found marked packets would never end up in the queue with the wlan2 parent, only in the queue with teh appropriate WDS parent.
Hi, im not sure about this but i have WDS working with queue trees.. Make a bridge and place as ports the WDS connection, the parent wireless interface of WDS and any other Ethernet you need to bridge, then make this bridge the default one in WDS config and not the WDS link itself! and make the WDS static…I think this will work fine
