Hi All,
I am a WISP that has 6 customers that require a service and am currently testing a RB133 for the following scenario:
Customer1 can see the AP, but the other 5 cannot; However, Customer1 can see all other 5 customers. I propose to use a RB133 as CPE for Customer1, while also using a 13dBi Base Station Antenna attached to the same RB133 to distribute a signal to the other 5 customers.
On the CPE/AP, wlan2 and ether1 are routed for the CPE side. wlan1 is ap bridge. I have enabled static WDS on wlan1. Added WDS interface with the CPE’s MAC address. Bridged wlan1 and wlan2.
For the other clients’ CPEs, I have set to WDS Station and enabled WDS and added the WDS interface with the AP’s MAC address. I then set up masquerading as normal.
This solution was implemented on the advice of my supplier, but it has not worked. Is there anything that I have overlooked?
Any advice or assistance would be very gratefully received.
Many thanks,
JF
