Using RB2011UiAS-RM as a vlan-aware switch
Hi.
I have my MikroTik RB2011UiAS-RM connected to a Cisco router that is a dhcp/dns server and provides with a number of vlans (guest and office in this case). Vlans are isolated from each other on that Cisco router for security reasons. Now I need to configure ports on RB2011 so that the device connected to the port accesses vlan that I need. Mikrotik does not need to DHCP or NAT.
To put it simply: Cisco gives 2 vlans. I connect my Mikrotik using its Eth1 interface to Cisco. How do I do: Mikrotik Eth.2-5 - goes to vlan 1. Mikrotik Eth6-10 goes to vlan 2.
I am a bit of a dummy so please be patient :slight_smile:
I would help, but you insist on using vlan1 for data so I will pass.
