Using RB750UP as a POE switch
I’m currently looking to use the MikroTik RB750UP as a POE switch.
I’d like to try and set up something similar to port based vlan.
Is there anyway to separate the ports without using vlan id’s?
Thanks!
Ive been using RB750UP’s all week using Vlans,
try having a look at the switch ports or possibly if your not wanting to use Vlans perhaps just adding the ether ports to bridges,
the vlan method you could either put a tagged vlan on the ether port or pvid it
Kev
Thanks for the reply kev.
I ended up just bridging all 5 ports and setting up each ethernet interface with Horizon.
Worked like a charm!
