I have the following setup:
TestDevice <=====>Microtik_Hex_S_router<=====>MyPC<====wireless====>ISP_Wifi_Router
Ether2Port_______________________________Ether3Port______VPN
I have tried a lot of settings but I seem to keep having problems with everything working properly.
What I am really trying to accomplish is the following:
- I need the Microtik to supply an IP address to the TestDevice using DHCP
- I need the Microtik to bridge the connection between the PC and the TestDevice
- I need the Microtik and the Wifi_Router not to fight with each other or create problems.
Currently I have the Microtik set up as a Bridge but I still seem to have the following problems:
- cannot connect reliably to the TestDevice from the PC
- sometimes the access to the internet via the ISP seems impacted
I can connect to the Microtik via Winbox.
It is currently set up as a bridge but I have tried router in the past.
I don’t see the PC or the TestDevice in the Neighbors screen even though I have the discovery settings all enabled.
I am just wondering what the settings should be for this type of configuration in order to have things work smoothly.
Thanks for any tips you can offer.
JR
