Using Router OS with one NIC
Hi All,
So here is my issue, i have installed router OS on a spare EEE PC and it has only one NIC.
the way i want to utilize it is a follows
(WAN)—>(DSL Router)—>(PC with Router OS)---->(Lan)
I want the pc to act as the default GW for all the LAN devices as well as NAT and proxy.
Is this possible, if not what other alternatives do i have.
Thanks.
U need managment switch to use it like that, and then set up some vlans to work.
