Using RouterOS to VLAN your network
Keep in mind that there is also a switch that connects via sfp1/2 to the router, please refer to the origin above. If the connection is via fiber from a switch, then it only makes sense to connect the other end to the fiber port on the router, and not on an ethernet port although one could do that (and pcunite does state connecting to ether ports as well) but then it defeats the purpose of connections via fiber. Why drive on 1st gear when you can switch to 5th gear?
I don’t deny that there can be more than one trunk port, but if this article is meant for newbies and amateurs, it is unnecessarily confusing. For this reason alone, the other purple colored boxes should be uncoloured, and changes made accordingly to the router.rsc file.
The purpose of this entire post is to help newbies understand and how to perform various real-world configurations, that is the basic premise.
If one looks at the router.rsc file, it does say that the tagged ports can also be ether2-7, and therefore coloring them purple is in-line with the way the diagram is colored. I don’t deny that. All I am saying is make it simple…plug a fiber port to a fiber port. Avoid saying it’s OK to plug to a fiber port at one end and to an ethernet copper port at the other, in which case one is teaching the wrong thing to newbies.
pcunite also says the post is also meant for network admins, I am sure this fiber to copper connection would look silly to them.
More importantly, keep in mind that lots of us MT newcomers will be referring to the post as well, some would also be new to networking.
You are a forum guru, so it is easy for you. But the MikroTik journey for beginners is very very frustrating, I can attest to that, so why add more confusion? Remember the KISS principle?
If the intent of this posting is to help newbies, then the purpose is defeated by this unnecessary coloring, this is my opinion.
In any case, thank you for having taken the effort and time to reply.
I understand what you’re aiming for but it’s not that uncommon.
I have a router with a CSS610 switch connected via SFP+ at home and still most of my router ports are trunk ports (only 1 access port, the 2.5Gb one for direct connection to my PC in my office and ofcourse the ISP uplink).
I am not the author of the original posts but the way I see it his aim was mostly to provide clarity on how to use VLANs in a ROS environment.
This is not about why use VLAN, when to use trunk ports, when to use access ports, …
Anyone able to grasp those VLAN related concepts, should be (I hope) smart enough to figure out when to use access ports and when to use trunk ports. This guide then gives you the handles how to implement it using ROS.
As far as being a guru, I’m far from. Don’t let post count mislead you.
Still learning new things … but I have been an absolute beginner too. I also started from zero with ROS and yes, the learning curve is steep.
But put in the time, experiment, start over and learn doing so.
Again, I do understand your position but I believe you’re misunderstanding (a bit) the real aim of this thread.
Concur Holvoe…
The post made is nonsensical, based on the experience on this forum I have seen all manner of setups and none of the threads examples seem out of place compared to that of which one is exposed to here. The intent of the article is to help users navigate through implementing vlans via vlan-filtering=yes, and the examples are 'fictionary and any resemblance to actual configs is not intentional, nor were any bunny rabbits harmed during the process. The post misses the mark by a continental mile.
Hi, need some help on these scripts. When I factory default the router, it has a default configuration already with bridge etc which conflicts with the script. I see the system “Start with a reset (/system reset-configuration)” note, but that doesn’t allow me to connect via winbox to then import the script. I’m sure I’m doing something lame since no one else seems to have encounter this issue.
Maybe you are just using the “wrong” method?
Winbox can connect to IP (that don’t exist after a reset) or to MAC (that does exist after a reset).
If in Winbox the device is detected, it will have a MAC and and IP of 0.0.0.0.
Make sure to click on the MAC, and that the upper box gets populated with it before clicking on connect.
Whenever possible, connection by IP Is to be preferred, but after a reset you can only use the MAC.
It doesn’t show up. I’m plugged into port 8 of the rb5009. The larger question is should I accept the default config or not?
Well, nothing prevents you from accepting the default configuration and later remove/delete it manually.
But it is strange that Winbox doesn’t see the router, you should try with another PC and on all other ethernet ports (except ether1)
This guide is great :slight_smile:
Does all the scripts work on RO7?
As far as I understand, the router is mostly trunks as in big networks, many switches are connected up to the router
Its an example only. Your assumption is as equally questionable as I have seen routers with all trunk ports, going to APs, switches etc. More than likely, would agree that a mix is more likely or not all ports are used.
In any case its just an example not to be taken at face value.
Yes the scripts work fine on RoS7. The only deviation comes when you start using capsman but thats another topic ( datapath is used to assign vlans or something like that)
I would like to solve the connection of the hAP ax3 router and the cAP ax access point with VLAN and CAPsMAN under ROS7 based on the description.
Unfortunately, there are problems with it.
I would use the Router-Switch-AP (all in one) configuration on the router, while the AccessPoint config on the access point. Of course, I modified it and set up CAPsMAN, but it doesn’t want to connect.
Is there a solution for this?
Thank you for your help
Hello @pcunite,
While searching for material to learn about VLAN, I found your magnificent post. Since networking is not a discipline I master at all, I took the liberty of translating it into Spanish as faithfully as possible to the original to facilitate its understanding and use your guide as study and experimentation material. I hope it will be useful to other spanish speakers and that I have not transgressed the purpose of this material or any other rule.
If any spanish speaker decides to make a comment, please do so in english as the common language of the forum. I have seen other sites that seem like the Tower of Babel.
Thank you very much in advance
Using RouterOS to VLAN your network by PCUNITE Mikrotik Forum Guru User in Spanish.docx (203 KB)
Using RouterOS to VLAN your network by PCUNITE Mikrotik Forum Guru User in Spanish.pdf (269 KB)
This help article does not address capsman, suggest you visit the wireless forum and peruse any topics with vlans.
Thank you for your advice.
Excellent. Thank you. Hope that helps the Spanish community.
After reading WHOLE thread, i must say original posts and few other posts, really concisely explained the matter - other posts only made me more confused : D
I have few observations (which i would like to know if true) and questions:
1. hardware offloading does the original post logic and setup, depends if mikrotik device is using hardware offloading or not ? Because that matter is still not clear to me.
If hardware offloading makes, lets say, communication between two VLANs done in switch chip, without the use of CPU , or if i didnt get that right - communication between two VLANs is done in switch chip which is INSIDE the CPU block, then
do we still need to make bridge itself as a tagged member of VLAN, in order to have intraVLAN communication (between VLANs) ?
Because the whole point of adding bridge itself as tagged member is to send tagged frames to cpu , if i am not wrong.
I don’t want to make topic more complicated with hardware stuff, but only interested does it changes some of the logics and configurations of original post .
4. ip address of the bridge when do you want to add ip address to the bridge itself - ip address add interface=bridge address=x.x.x.x?
is it for example when you have bridge pvid=1 and you want l3 access to cpu, from port (member of the bridge) in vlan1 ? (for managing device, or routing outside of vlan1)
OR, is it used as in cisco world where bridge interface is used to send packets outside of the bridge ?
5. firewall logic and lastly just one question about firewall logic, using pcunite example :
0.add chain=forward action=accept connection-state=established,related comment=“Allow Estab & Related”
1.add chain=forward action=accept connection-state=new in-interface=RED_VLAN comment=“Allow RED_VLAN to access the Internet AND other VLANs”
2.add chain=forward action=drop comment=“Drop”
now if add a line for RED_VLAN to access only internet :
add chain=forward action=accept connection-state=new in-interface=RED_VLAN out-interface=wan
i tested this in gns3, and it doesnt change anything - still get access to internet AND other vlans, regardless if i put this rule before 1.line or after 1.line
how to explain that firewall logic? if there are two same rules, with one being restricted , it will ignore it and use less restricted rule ?
tnx
For the first question reading herehttps://help.mikrotik.com/docs/spaces/ROS/pages/328068/Bridging+and+Switching#BridgingandSwitching-BridgeVLANFiltering
Currently, CRS3xx, CRS5xx series switches, CCR2116, CCR2216 routers and RTL8367, 88E6393X, 88E6191X, 88E6190, MT7621, MT7531, EN7562CT switch chips (since RouterOS v7) are capable of using bridge VLAN filtering and hardware offloading at the same time, other devices will not be able to use the benefits of a built-in switch chip when bridge VLAN filtering is enabled. Other devices should be configured according to the method described in the Basic VLAN switching guide. If an improper configuration method is used, your device can cause throughput issues in your network.”
For the second question:
Never IMHO, once you go vlans, the bridge should not normally be involved in DHCP again. However MT is extremely flexible and there may be some niche configs that require this.
Note that the bridge vlan-id default is 1, it works in the background and normally should not be considered as management vlan or used for any data, just leave it alone!!
For the third question
First of all I disagree with PC Unites approach. I personally do not permit or use open ended firewall rules. I prefer to have a clear source and clear destination for all my rules, even If I have to make additional rules. In this regard less inferences need be made.
Secondly, its a misnomer almost to put in connection-state=new, the reason being is that only the first packet of the connection is new, subsequent packets it established related etc…
Thus for each session, the rule is only new for the first packet and subsquent packets dont hit the rule. No one uses connection-state=new.
I have seen that used in some mangle rules, where it may be useful to pinpoint traffic being mangled.
The rules set assuming for a router should read
{ default rules to keep }
add chain=forward action=fasttrack connection-state=established,related
add chain=forward action=accept connection-state=established,related,untracked
add chain=forward action=drop connection-state=invalid.
( admin rules )
add chain=forward action=accept chain=forward comment=“internet access” in-interface-list=LAN out-interface-list=WAN
add chain=forward action=accept chain=forward comment=“port forwarding” connection-nat-state=dstnat disabled=yes
{ enable if required or remove }
******* → Add any other allow rules here ← ************
add chain=forward action=drop comment=“Drop all else”
With that in mind lets look:
Focussing on rule 1
It says → Allow the Red VLAN (assuming its base/trusted/management) to anywhere ( thus to other vlans, and to WAN, perhaps to wireguard vpn if it was available )
The second rule say, drop everything else… So no other traffic not permitted above this rule will not traverse the router etc.
If you add the third rule explicitly allowing the red vlan out the WAN, it will NEVER have any effect.
a. in case A you stick this rule after the drop rule, ITS TOO LATE, you have already dropped everything,
b. in case B you stick it before the drop rule, its redundant! You already let VLAN red anywhere so its gone out the internet and the rule will never be hit.
Typically we assign all the vlans as members of the LAN interface list.
in cases lets say we have 8 vlans that need to go out internet and 1 vlan that does not
we can make the standard rule look like
add chain=forward action=accept comment=“internet access” in-interface-list=LAN out-interface-list=WAN src-address=!192.168.9.0/24
Or you could have a interface LAN list that simply doesnt include that VLAN and the standard rule works.
Or you could make a separate interface LAN list called With-Internet
add chain=forward action=accept comment=“internet access” in-interface-list=With-Internet out-interface-list=WAN
There are so many ways to accomplish the same thing so its part knowing the rules and tools and part imagination.
>> hardware offloading?
As anav pointed out, it depends on the hardware.
>> when would you assign an ip address to the bridge itself?
When using VLANs, you would not do this. The Bridge is just a mechanism to manage your VLANs which are the only thing that really needs to be exposed.
>> firewall logic?
FW logic is personal. I only show examples. All my rules are drop by default. So, unless you open up something, prior to the drop rule, it will get dropped. Rules are processed in order, and thus anything placed after a DROP rule will never fire (unless jumping). I used connection state new to fire the red vlan rule and thus stop further processing. But there are other ways to go about this.
Hi, pcunite
Thank you for the vlan guide!
