hellow every body …
can we use the device above / sxt 5hnd / as a complete pppoe server using wireless system
( hot spot station )
i hope y understand me
thankssss
hellow every body …
thankssss
it has a directional antenna, how would your clients connect to it?
The SXT has a pretty wide beam width. 15° to 25°
so it should work like a sector antenna.
A sector antenna for one client? That device has a level 3 license.
Better get the OmniTIK. It will be cheaper than adding a L4 license to SXT, and then getting 6 other SXTs to cover a reasonable area.
It is not really available right now.
And if the stations are within the beam-area nothing should argue against using an SXT as AP.
It is available. But I see you are in Germany, then it isn’t. The OP is outside of Europe, he has OmniTIK available already at his distributor.
Additional price for L4 license (45$) argues strongly ![]()
But the SXT has a better gain than the OmniTik. 16dB vs 9dB.
thanks very much to all friends
but i suggest if the mikrotik company reproduct the device to another aim
a device that can any body in the world use it as ( hotspot station )…
any body can use this device as internet srevice controller and believe me this will be a very great production from mikrotik company
thanksssssss again
