At this point the only way to open the winbox from Dude is to specify the user and password in the device. Is there a way I could get it so someone right clicks the device, then goes to Tools → Winbox and can specify their own user name and password?
The user I have set in configuration is a read only user to read stats. I would really prefer each person their own login when connecting to each router/AP rather then one login accessed through the Dude.
you can configure your own tool - just make a tool to run winbox with parameters of address (that will be a variable) and username. so you could make one tool for running winbox without a username entered, and one that runs winbox with a specific other username, for example
I wasn’t even aware you could do custom tools, excellent! Is there a way I can add this custom tool to every single device rather then having to manually go through every single one and add this custom tool?
go into tools (on the left panel), add a new one, set the command that you want to run, and then specify which types of devices this tool will be for - you can also select All, which is the default
