using Usb-Ethernet Adapter
hello
I have RB411 with V5.18
I’m trying to connect to him D-link usb 2.0 Fast Ethernet Adapter DUB-E100
but it doesn’t work for me.
In the resources I can see him
what is the problem?
Thanks,
Send supout to support@mikrotik.com, they may need to add it to the next version.
I will send them
thanks ,
Same problem on x86 with the DUB-E100 on 5.21. Specifically purchased this adapter as it is listed in the Supported Hardware section, clearly there is some regression or D-Link has changed the internal chipset.
Any plans for fixing? I see this is up in various places online.
I have the same problem.
