I was reading the MetaRouter requirement section in the Wiki and it mentions it is possible to use VLANs to overcome the current limitation of 8 VIF’s per VM instance.
Can someone post an example of how this is accomplished?
I am unable to come up with a working configuration in my testing.
assigning a lot of interfaces just adds a lot of overhead. Better tell us why you want a lot of interfaces for guest and it can be worked around.
On the other hand i do not see why you could not receive VLANs in Metarouter. If you statically assign interface to the metarouter guest, you will receive packets as is in the guest. And in the guest itself, ethernet is the usual interface from host RouterOS.
