What are the procedure how to configure using WINBOX to access
RB750G via Remote Management… using PUBLIC IP WAN side
DSL-DlinkRouter-RB750G
What are the settings need to open Virtual Server in the Dlink Router
What are the settings in the RB750G
Please help…
Dexlaine
fewi
September 27, 2010, 2:16pm
2
On the D-Link, forward the port configured under “/ip services” for Winbox (look that up on the RB). By default you don’t have to do anything on the RB if there are no firewall rules installed. If there are, open up that port.
I’ve done all the firewall settings but still cant access…
Dexter
fewi
September 28, 2010, 3:48am
4
Post “/ip firewall export” from the RB.
normis
September 28, 2010, 7:15am
5
RouterBOARDS drop everything in the input chain for the public port.
What should I do with the RB is there any configuration to be done?
normis
September 28, 2010, 11:42am
7
post the export as fewi asked, please
Sir,
Here is the configuration I posted
Dexter
Please find some possible problem about port forwarding
I just to view the userman via WAN side cause the RB750 is in the REMOTE area
Dexter
fewi
October 6, 2010, 2:51pm
10
Remove all the IP firewall filter rules that do not have a ‘D’ in the status column.
It’s much easier if you copy and paste the result of “/ip firewall export” rather than take a screenshot of the window you ran the command in, by the way. Easier for you to post, and easier for us to read.
[admin@Dexlaine] > /ip firewall export
jan/02/1970 00:01:01 by RouterOS 4.9
software id = 32J2-H89G
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input comment="default configuration" disabled=no
protocol=icmp
connection-state=established disabled=no in-interface=ether1-gateway
connection-state=related disabled=no in-interface=ether1-gateway
add action=drop chain=input comment="default configuration" disabled=no
add action=masquerade chain=srcnat comment="default configuration" disabled=
no out-interface=ether1-gateway
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=n
dexlaine
configer your adsl modem on brideg mode and config your Adsl account in pppoe mode in ur Rb u can use it with winbox and userman
