Utilizing VLANs on CRS125 using the switch chip with Unifi
I’m fairly new to RouterOS and VLANS in general. I’m trying to utilize the switch chip in my CRS125 to create a VLAN for a guest network using 4 Unifi UAPs. I’ve read and re-read a lot posts but I can’t figure out how to make it work. It looks to be easier to set up VLANs using a bridge setup but I’d like to learn how to configure them using the switch chip. My network is setup as follows:
LAN = 192.168.2.0/24
WAN1 = Ether1
WAN2 = Ether2 (future)
Masterport = Ether3 (all other ports set to Ether3 as master port)
Unifi AP1= Ether18
Unifi AP2 = Ether20
Unifi AP3 = Ether22
Unifi AP4= Ether 24
SSID 1 = unrestricted access (would like to have untagged so it can reach wired LAN)
SSID 2 = Guest network with VLAN 200
From the CRS examples page I’ve done the following:
admin@CRS125-1-381-05661] /interface ethernet switch ingress-vlan-translation> print
 0 X ports=ether18,ether20,ether22,ether24 service-vlan-format=any customer-vlan-format=tagged customer-vid=1 new-customer-vid=100 pcp-propagation=no
     sa-learning=yes
I read that you need to assign untagged traffic a tag when it was on a port with tagged traffic. I used VID 100. Is this correct?
admin@CRS125-1-381-05661] /interface ethernet switch egress-vlan-tag> print
 #   VLAN-ID TAGGED-PORTS
 0 D    4095
 1 X     200 ether3-master-local
             ether18
             ether20
             ether22
             ether24
admin@CRS125-1-381-05661 /interface ethernet switch vlan> print
 #   VLAN-ID PORTS                                                   SVL LEARN FLOOD INGRESS-MIRROR QOS-GROUP
 0 D    4095 WAN-1                                                   no  no    no    no             none
             WAN-2
             switch1-cpu
 1 X     100 ether3-master-local                                     no  yes   no    no             none
             ether18
             ether20
             ether22
             ether24
 2 X     200 ether3-master-local                                     no  yes   no    no             none
             ether18
             ether20
             ether22
             ether24
When I enable all of the above, I can still connect on SSID 1 but not on SSID 2. I won’t even get a DHCP assignment on SSID 2. When using the switch chip do I still need to add an IP pool, etc to VLAN 200? Or should it pull from the existing IP pool used by SSID 1? Where does the switch chip interface come it to play? Do i have to tag the VLANs on the switch chip as well as the master port?
I’d appreciate anyone that can jump in and straighten me out, Thanks.
I don’t know that you can specifically tag VLAN traffic on MikroTiks… I assume you have your VLAN setup in the Unifi controller? I would create your guest VLAN on the Tik with its own subnet and pool of addresses. If the UAP ports are set to master port 3 it should work. If not then you need to create a bridge to include all the UAP ports and the VLAN.
I do have the VLAN setup in the UAPs also. I was hoping to utilize the switch chip to do this instead of bridging but I may have to resort to that as I’ve hit a wall and can’t get it to work.
You are correct, a bridge may be in order…
