Good Morning All,
I am currently running 6.24 and I have been trying and trying to get this port forwarding squared away. I have searched up and down and tried everything known to man to get this stuff working. All I can think of is that my fw is blocking it some how. Here is my fw print out. I am trying to forward 5900 UDP/TCP to an internal IP of 192.168.29.229 I have tried all the suggested methods and still think my FW is borking it.
ip firewall export
# jan/13/2015 15:53:51 by RouterOS 6.24
# software id = WI6S-NMRP
/ip firewall address-list
add address=122.0.0.0/8 list=src_reject
add address=61.0.0.0/8 list=src_reject
add address=5.0.0.0/8 list=src_reject
add address=123.0.0.0/8 list=src_reject
add address=192.168.128.0/20 list=ALLOWED_PRIVATE_NETS
add address=10.7.0.0/20 list=ALLOWED_PRIVATE_NETS
add address=172.24.0.0/24 list=ALLOWED_PRIVATE_NETS
add address=172.16.0.0/16 list=ALLOWED_PRIVATE_NETS
add address=224.0.0.5 list=ALLOWED_PRIVATE_NETS
add address=115.88.95.53 comment=cortana.homelinux.net list=\
Host_Trusted_remotes
add address=127.0.0.1 list=QOS_HIGH_PRIORITY
add address=224.0.0.5 list=QOS_NETD_PRIORITY
add address=127.0.0.2 list=QOS_NORMAL_PRIORITY
add address=192.168.88.249 list=QOS_NORMAL_PRIORITY
add address=23.76.0.0/16 comment="Amazon and Target" list=HMA_VPN_OUT
add address=72.246.103.24 list=HMA_VPN_OUT
add address=114.108.0.0/16 list=HMA_VPN_OUT
add address=176.32.0.0/16 list=HMA_VPN_OUT
add address=192.168.88.2-192.168.88.254 list=LOCAL_VPN_NET
add address=192.168.89.0/24 list=LOCAL_VPN_NET
add address=216.127.0.0/16 list=HMA_VPN_OUT
add address=173.194.117.0/24 list=HMA_VPN_OUT
add address=173.194.126.0/24 list=HMA_VPN_OUT
add action=drop chain=input comment="SRC Reject DROP" log=yes log-prefix
"SRC_REJECT: " src-address-list=src_reject
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="Accept ESTABLISHED" connection-state=establishe
d
add chain=input comment="Accept Related" connection-state=related
add action=jump chain=input comment="Process GRE Input" in-interface=\
!ether1-gateway jump-target=proc_gre_in src-address=!192.168.88.0/24
add chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add chain=input comment="allow sstp" dst-port=443 protocol=tcp
add action=drop chain=input comment="Catch-All DROP" in-interface=\
ether1-gateway
add chain=forward comment="Forward ALL THE THINGS!"
add chain=forward comment="default configuration" connection-state=\
established disabled=yes
add chain=forward comment="default configuration" connection-state=relat
ed \
disabled=yes
add action=drop chain=forward comment="default configuration" \
connection-state=invalid disabled=yes
add action=jump chain=output dst-address=!192.168.88.0/24 dst-address-li
st=\
ALLOWED_PRIVATE_NETS jump-target=proc_gre_out out-interface=\
!ether1-gateway src-address-list=ALLOWED_PRIVATE_NETS
add chain=output comment="Accept Output"
add chain=proc_gre_in dst-port=500 in-interface=!ether1-gateway protocol
=udp \
src-address=172.16.0.0/16
add chain=proc_gre_in in-interface=!ether1-gateway protocol=gre src-addr
ess=\
172.16.0.0/16
add chain=proc_gre_in in-interface=!ether1-gateway protocol=ipsec-esp \
add chain=proc_gre_in in-interface=!ether1-gateway protocol=ipsec-ah \
add chain=proc_gre_in in-interface=!ether1-gateway protocol=icmp src-add
ress=\
172.16.0.0/16
add action=drop chain=proc_gre_in in-interface=!ether1-gateway log=yes \
log-prefix="FW-DROP_GRE_IN: " src-address=172.16.0.0/16
add chain=proc_gre_in in-interface=!ether1-gateway src-address=!172.16.0
.0/16 \
add action=return chain=proc_gre_in
add chain=proc_gre_out dst-address=172.16.0.0/16 dst-port=500 out-interf
ace=\
!ether1-gateway protocol=udp
add chain=proc_gre_out dst-address=172.16.0.0/16 out-interface=\
add action=drop chain=proc_gre_out dst-address=172.16.0.0/16 log=yes \
log-prefix="FW-DROP_GRE_IN: " out-interface=!ether1-gateway
add chain=proc_gre_out dst-address=!172.16.0.0/16 dst-address-list=\
ALLOWED_PRIVATE_NETS out-interface=!ether1-gateway
add action=return chain=proc_gre_out
/ip firewall mangle
add action=change-mss chain=forward dst-address-list=ALLOWED_PRIVATE_NET
S \
new-mss=1418 protocol=tcp tcp-flags=syn tcp-mss=!0-1350
S \
add action=mark-routing chain=prerouting comment=HMA_VPN_TRAFFIC disable
d=yes \
dst-address-list=HMA_VPN_OUT log=yes new-routing-mark=VPN_TRAFFIC_OU
T \
src-address-list=LOCAL_VPN_NET
add action=mark-routing chain=prerouting comment=HMA_VPN_TRAFFIC \
dst-address-list=HMA_VPN_OUT log=yes new-routing-mark=TEST_VPN \
add action=mark-connection chain=forward comment="INPUT - QOS_NETD - Mar
k" \
in-interface=bridge-local new-connection-mark=NETD src-address-list=
QOS_NETD_PRIORITY
k" \
dst-address-list=QOS_NETD_PRIORITY in-interface=bridge-local \
add action=mark-connection chain=forward comment="OUTPUT - QOS_NETD - Ma
rk" \
dst-address-list=QOS_NETD_PRIORITY new-connection-mark=NETD \
out-interface=bridge-local
rk" \
new-connection-mark=NETD out-interface=bridge-local src-address-list
QOS_NETD_PRIORITY
add action=mark-connection chain=forward comment="INPUT - QOS_HIGH - Mar
k" \
in-interface=bridge-local new-connection-mark=HIGH src-address-list=
QOS_HIGH_PRIORITY
k" \
dst-address-list=QOS_HIGH_PRIORITY in-interface=bridge-local \
add action=mark-connection chain=forward comment="OUTPUT - QOS_HIGH - Ma
rk" \
dst-address-list=QOS_HIGH_PRIORITY new-connection-mark=HIGH \
rk" \
new-connection-mark=HIGH out-interface=bridge-local src-address-list
QOS_HIGH_PRIORITY
add action=mark-connection chain=forward comment="INPUT - QOS_NORM - Mar
k" \
in-interface=bridge-local new-connection-mark=NORMAL src-address-lis
t=\
QOS_NORMAL_PRIORITY
k" \
dst-address-list=QOS_NORMAL_PRIORITY in-interface=bridge-local \
add action=mark-connection chain=forward comment="OUTPUT - QOS_NORM - Ma
rk" \
dst-address-list=QOS_NORMAL_PRIORITY new-connection-mark=NORMAL \
rk" \
new-connection-mark=NORMAL out-interface=bridge-local src-address-li
st=\
QOS_NORMAL_PRIORITY
add action=mark-packet chain=forward comment="QOS_NETD - Queue" \
connection-mark=NETD new-packet-mark=NETD passthrough=no
add action=mark-packet chain=forward comment="QOS_HIGH - Queue" \
connection-mark=HIGH new-packet-mark=HIGH passthrough=no
add action=mark-packet chain=forward comment="QOS_NORM - Queue" \
connection-mark=NORMAL new-packet-mark=NORMAL passthrough=no
add action=mark-routing chain=prerouting dst-address-list=Tunnel \
new-routing-mark=tunnel
add action=masquerade chain=srcnat comment="Hide My Ass VPN" out-interfa
ce=\
HMAovpn-Client
add action=dst-nat chain=dstnat dst-address=XXX.XXX.XXX.XXX dst-port=5900
in-interface=ether1-gateway protocol=tcp to-addresses=192.168.88.248
add action=masquerade chain=srcnat comment="masq. vpn traffic" disabled=
yes \
out-interface=HMAovpn-Client src-address=192.168.88.0/24
add action=masquerade chain=srcnat comment="default configuration" \
out-interface=ether1-gateway
Any help would be much appreciated…I have tried everything it seems so it HAS to be my fw. Help ![]()
