Using Shielded 24AWG AMP(branded) STP cable.
Using POE .. even tried to put Mikrotik 18v Power Suppy direct on RB112 and access data on the 40m cable still problem..no problem with shorter UTP.
Conclusion not power problem.. data signal problem.
Interface Ethernet Monitor - link is ok
Each ethernet segment can be 100m, I’ve deployed 110m lengths but then had trouble getting PoE to work but not data. PoE standard also works to 100m but I think you will need to use 48v power supply
" boards are compliant with IEEE802.3af Power over Ethernet standard (except power over datalines) and accept 48V powering over up to 100m (330 ft) long Ethernet cable connected to the Ethernet port (J5 or J6)."
I can connect with shorter (< 40m) POE cable , so my POE should be OK.
But then again straight supply to power input and long POE won’t work.
I am using CAT5e STP cable
There is also a mention
" In case it is planned to power the board up from a
standard 48V DC PoE injector (note that the RouterBOARD
does not support power over datalines), the JP2 jumper
should be opened."
Maybe I should try this tomorrow. Need to look for the JP2 jumper..
Anyone have tried the need to remove this jumper before.
on a serious note; i’ve send 18v PoE across 200ft to a Pac Wireless PoE breakout box (great little 20$ device that lets u power ANYTHING within PoE’s power margins)
My first guess would be that your cable either has a pinch in it or a bad connector crimp. 40m is easy to get data and poe across. Try with another cable just sitting there coiled up in front of you.
