V.5 in VirtualBox and licence qst.
Hi to all!
I downloaded RouterOS 5 beta1. For some reason I use Sun VirtualBox to test RouterOS itself and create another virtual machines as client computers. On version 4.6 it works well. But v.5 can’t be installed from .iso in virtual machine, don’t know why. I installed it successfully only via netinstall but system halt on boot time. You can fix it: go to Settings->System->Processor and disable checkbox named “Enable PAE/NX”; after that RouterOS v5 started.
I was considering to buy licence for 4.6 and we got v.5 now. Can someone give me advice: what version better use nowdays? :open_mouth:
Thanks in advance.
Hi konstg
V5 is a beta and not to be used in production environment. If i look in to the history RouterOS is in beta for approximately 1 year befor going to stable releas. If you buy a license now you are able to upgrade to V5 later without paying for the upgrade.
Thanks a lot, leoktv!
You really lighten up my licence issue :slight_smile:
Excuse me, leoktv, did you mean license level 4 for v.4.6 can be upgradable to v.5? I asked because recently read this page:
http://wiki.mikrotik.com/wiki/Manual:License_levels and was going to buy exactly level 4… :open_mouth:
Level number 0 (FREE) 1 (DEMO) 3 (WISP CPE) 4 (WISP) 5 (WISP) 6 (Controller)
Price no key registration required volume only $45 $95 $250
Upgradable To - no upgrades ROS v4.x ROS v4.x ROS v5.x ROS v5.x
Hi you can’t upgrade from level4 to level5 only ROS 4.x to 5.x
thank you, Leo.
