Dear All,
I am using firmware 7.14.2 on routerboard model RB750Gr3 with firmware type mt7621L
Since that version the table with the firewall rules ( IPv4 and IPv6 ) is almost unusable because of a strange column width layout.
The third column (#) with the rule numbers is extremely wide, but the fourth column (Comment) is to too narrow.
I testet with Chrome and Firefox with the latest version. In both browsers the same behaviour.
Hopefully soon a fix in the next version.
You should also be able to change the width of each column yourself? Hover with your mouse between two column headers, note that the mouse pointer turns into a double arrow and then drag left/right while holding the left mouse button to change the column width.
If that doesn’t work maybe one of stylesheets or scripts got blocked by your browser for whatever reason? Or maybe try incognito mode to make sure it doesn’t use a corrupted browser cache..
Thanks to all for these hints.
I cleared the cache, it worked. But then the issue came back.
Working within an incognito window seems to be one solution.
Also incognito window does not help. It looks ok when opening fresh but after a time the column width is destroyed.
Changing the design skin does not solve the issue too.
But this was not always so. It came with one of the last updates.
As it’s annoying I hope for a fix with an upgrade.
