After upgrading a hundred or so clients on SR9s from version 2.9x there seems to be issues with the cpes not showing there ip address the cpes where and are assigned in example ip/neighbors.. they randomly show up as all zeros. If I go into the cpe to check its ip, the originaly assigned ip is still there. Sometimes after rebooting the cpe, its ip comes back, but I have many that i have rebooted many times and the ip shows still zeros. Customer seems to be able to surf the net as usuall but this could be a potential headach for sys admin, if he needed to really access the cpe via ip or some other things im sure.. Also another issue that im seeing occasionally with 3.10, is that a cpe is sometimes not able to find its way or complete its route back to the main server with hotspot and dhcp.. When looking at my neigbors from main sevrer, I cant see the suspecting cpe, if i log into the server that i know the cpe looks at, well there i see it no problem, and with good signal in the high 60`s. I cant seem to log into the cpe because it cant route poperly back to main server, customer then has to disconnect cpe and reconnect which usually soves the problem.. This is a problem…
I’ve seen the issue with the 0.0.0.0 address and the regular address for a cpe both showing up. I seems that it is getting the information from the bridge rather then the Ethernet port where the IP is assigned. The 0.0.0.0 mac should match the wireless card. Must be a bug, but it does not seem to have any impact, on our system that I have seen so far. It also seem to correct its self over time.
Erik
bump… im bumping my threads, cause they are real problems that need to be addressed…
Have not been able to replicate here
oddd, in one cell with around 50 clients, i have constently around 4 to 7 cpe with zero IP`s, rarely they go away, but are always new ones to take place…
