The PPPoE-Client on my Mikrotik-3.14 (PC) router keeps getting a 10.x.x.x ip address instead of the Public IP from the RADIUS server.
I have tried two different PC’s and different NIC in each.
The LAN side NIC has an ip address of 192.168.0.1/24
src-NAT is setup with out-interface=pppoe-out1
The pppoe-out1 interface is the “WAN” NIC
The PPPoE connection authenticates and says connected.
I have even tried two different DSL routers (bridged)
I have tried passing a username/password that has an assigned IP address and one that has dynamic IP address and I get the same response from both.
Discovered that unchecking “Dial on Demand” allowed the pppoe interface to get the public IP. Is DOD unchecked a “nailed up” connection?
Now I can do nslookups (DNS is working) but I still can not get to websites.
My Mikrotik 2.9.5 router/PC works great thru the bridged dsl router.
It has DOD checked.
Any ideas why this would be happening or a fix would be appreciated.
