V3.27 per Rod
I’m gonna run a little blog of my system upgrade to v3.27
I just completed about half of my system.
So far it has no problems.
I’m gonna try the power out test later today.
And the speed test after that.
I’ll report back what I find.
Rod
OK - the rest of the network is done.
Everything looks good so far.
We will be doing more testing this weekend.
Rod
We have had no failures and the network is rockin’!
Looks good guys.
Rod
:laughing: :laughing: :laughing:
it’s not interesting
Hi Rod,
good to hear. Are you using OSPF/BGP with 3.27? Routing or routing-test?
Stefan
I would also like to know if you are running BGP in 3.27
I am having issues with a 3.27 router not correctly receiving routes from another.
Any body else using 3.27 routing package and BGP? I also run ospf on these routers for internal routes.
what exactly is not correct? do you use routing-test package? if no - try it
hey rod, i posted a reply to a diff thread you posted in. Can you send me pics and details of the grounding setup you use?
amirm@tierpath.com
