yeah, good point Tom.. Lessons to be learnt.. I guess the rb133 is a bit old in the tooth and I bet not much pre-testing was done using v3.3.
Now I have the daunting task of trying to downgrade to 2.9.51 without loosing any settings (else I will be unable to connect wireless and then need personal access, which needs prior booking)
I has same problem. But i found solution for this situation. But i don’t know, will it be solution for your problem. I use my RB133C as CPE. I just update it from ROS 2.9.51 to 3.30, after 3.30 up to 4.0rc1 with following npk. (dhcp,routering,system and wireless)
Reason your RB133’s hungs (power outage) is not enough memory (when it counts to 2300kB free memory, it’s reboots)
Use only those npk u need.
I think u will not lose any settings on upgrade, but if im wrong, u can go to File and make a backup, then download it from RB to your PC and store them into save place.
