V3 b5 on wrap won't reboot
Hello
It seems that V3 b5 wont reboot, just hangs when you choose reboot.
power cycle will fix
I have routerboard package installed.
:slight_smile:
Could a Mikrotik staff member tell me if this is a known issue?
I am very happy with the beta except for this :slight_smile:
we donโ€™t have any to test with, but we will try to find out why this happens.
Iโ€™d be happy to test for you.
I am not sure but I think its in the shutdown not the startup.
When I plug into the wrap rs232 I can see it boot, ram counts yada yada but when reboot from ros I dont see anything at all.
Perhaps some service sticking on shutdown waiting for something?
