Hello
I installed b5 on a really crappy link to see what happens
I noticed it is very fast to accocate with AP, much faster than v2
Looks like we have much to look foward to
Hello
Good to hear
What I would like to see is some sort of intelligence between multiple
ROS on the same tower handling interference and such crappy links.
Just what a human operator does when he sees trouble on one
tower. Measure Performance, Change channels, select usable rates,
use a phase of low traffic to reorganize Channel usage.
Some sort of DFS++.
Just dreaming of throwing routers on a tower and travel to
the sun relaxing and dreaming ![]()
Stefan
If you use 2,4Ghz Turbo mode please confirm I tested yesterday and in 2.8.39 can select but in Beta3 or Beta5 cant.
Send picture and support.rif to support.
Best regards.
More info
it seems on this bad link that would disconnect often, now will disconnect and reconnect in the same second!
Cust will not even drop a voip call
Fan Flaming Tastic!!
We tested Beta5 on a PtP link that had been running 2.9.27 on a RB532. The packet loss problem we began seeing in Beta4 still exists. As the link begins passing up to 5 Mbps of traffic, packet loss occurs. It starts out as dropping 10 packets in a row every minute or so and slowly increases until the link becomes nearly unusable.
Dropping back to 2.9.27 fixes the problem.
Speed tests and pings look encouraging. Seeing 32Mbps transfer rates and better ping times on RB532s.
supout sent to support.
I have only b5 cpeās not apās atm, this may be why i have no problems.
Grrr. Channels are still incorrect for Ireland, and possibly many other counties.
5725 ā 5875MHz cannot be accessed!! This is a basic feature that needs to be fixed now - way ahead of anything else.
http://www.comreg.ie/5_8GHzRegistration.asp?S=4&NavID=198&M=
Malcolm
I have two routerboards making dual nstream - will change to v3beta help with cpu load of routerboards (all the time 100%)?
Regards,
Gregor
I installed b5 on a radio that used to give me the dreaded ājoin timeoutā
It no longer has this problem ![]()
May be just a fluke but im not sure.
I really am hanging to get into this V3, I like it already
Has V3 got a new Wireless Driver?
dual nstreme requires a lot of CPU power, your RBās are probably running at their maximum capacity
14/15 Mbps. Is it all for them? Will v3 help with cpu load?
Gregor
itās not the megabits, itās the nstreme itself - itās a complicated algorythm which requires a lot of power to show itās capabilities. if you put it on a gigahertz system, it will show you what it can.
routerboard can push 200mbits through it in pure routing, over ethernet. so speed is not the issue.
OK, but you havenāt asnwered - will soft v3 help? Or it has nothing to do with cpu load?
Gregor
yes, it is a little optimized, but you should also test your links without nstreme and see if your antennas are correctly aligned, they are not too close, the frequencies are chosen correctly, the cables have no problems etc. only after you have perfect links, then you can use nstreme to improve speed.
Hi Normis
Can you explain a tad further?
Are you saying that nstreame will really only help with a very good link (say -70)?
I have found nstreame to be very good from speed and keeping oings low under load but seems to be fussy.
(does not like -80, does not like noise)
Is this the case?
Is anyone having any luck with Beta5 on an AP with NStreme?
are you still having problems with wireless?
what is your hardware setup and wireless configuration?
We are using RB532s and RB112s with NStreme and polling. Weāve tried it on APs and CPE and nothing works. CPEs need to be rebooted, APs drop all customers and require a reboot and a point-to-point link we tried (ap bridge to station wds) starts dropping packets like mad. All but one was a ābasicā configuration as a wds bridge. One had an IPSEC tunnel on it but they all required hard reboots.
We couldnāt generate a supout, so we e-mailed an /export of our system.
I can only comment on station mode (some with some without nstreame)
I have only 3 betaās running atm, all wraps
For me its been great, no lockups, no ājoin timeoutsā, and very fast to assiciate.
I must admint tho, these only do about 4mbps. (shaped at noc)
When Mikrotik fix this problem I hope they dont undo all the good about it.
Is anyone tested Beta5 in AP-bride mode?
