v3 Synax Highlighting
Is there a way to turn off the syntax highlighting in v3.0?
Thanks,
Wes
What's new in 3.0rc14:
*) console - added login parameters, passed as part of login name, after '+';
    can be used to disable colors (+c) and terminal autodetection (+t), e.g.
    "admin+ct";
That worked. Thanks.
Opps, No it did not.
It does if I use ssh interactively. But not when I have a user that has a ssh-key generated. user+c@… requires a password because the username has changed and does not match the ssh-key then.
Any other ideas?
I have written to Mikrotik tech support hopefully I will get an answer from them.
Thanks,
Wes
An update.
Received an email from Mikrotik support that there will be a fix in v3.2.
No information on what this fix will be.
Wes
