v4.0beta4 UM BuGs
settings are removed after restarting MT & admin login failed have to restart this issue still exists.
Did not quite understand. You cannot login with admin customer, as before? And there is no “Settings” section in web page?
  1. Settings are removed after restarting MT. (in beta3 it happened when cutomer logout & logged in)
    eg. table columns don’t know about others settings
    There are two kinds of pages in User Manager Web: Customer Pages and User Pages. This bug probably pops out after you have logged into “User page”. Am I right? I.e., after logging into user page it is impossible to log into customer page.
We are aware of this bug and working on a fix for it.
  1. Admin login failed have to restart this issue still exists.
I don’t know this is bug or it is made to work like that!
in settings table columns i have added few columns from hidden to visible then i logout & logged in again every columns were on the right place but when i logged in with same customer on other pc all columns were disappeared & set to default one.
I will have to set columns on every pc?
No, settings are stored for each customer, but not for each PC. So this is a bug. We fixed some bugs related to saving setting, but seems like, some still exist.
Which permission level the customer has? Owner/Full/Read-Write/Read-Only?
Does “setting-disappear” bug exists only for column ordering, or also for style?
read-write i will try on full also & tell u.
not for style only columns
also can you add total numbers of users on search page, active session, users & active users page.
I have a serious problem here i get this problem every 5 mins while adding new user.
Do you type in the username or do you paste it into the box?
I noticed in 4.03b that many times if i copy and paste into any of the fileds, it doesn’t save my changes, unless i type it out manually.
I haven’t had cause to check in 4.04b, but i was thinking if you’re pasting into the username field, it may be the same problem.
we login into one customer from 4-5 pc to register users, we can copy paste username & everything & it can be registered but u can see the background is blank & when we click on Add we get username is required message & when we click again on add the webgui logout automatically.
Could be, that fixing “Invalid user profile” bug (http://forum.mikrotik.com/t/fixed-user-manager-v4-0beta4-package/30406/21) will fix also this bug.
Thanks alot girts
by mistake i opened http://routerip/username & login page appeared & i tried to login into it with customer id login was unsuccessful then i tried with correct link http://routerip/userman then also i was unsuccessful to login with customer id so i restarted router then i logged in successfully. i think this problem is similar with user page login issue.
Yes, this is the same bug: if you open http://routerip/user… , it opens UM User page.
50% CPU
Free Memory 1834.5 MiB of 1900.1 MiB
I have quadcore processor with 1GiB 10ports.
I use pppoe network Only.
I have this profiles 64kbps 128kbps 256kbps 512kbps
but i have opened 100mbps for local traffic coz v have dc++ in out local network but user hardly get 1mbps in pppoe from MT but without MT they get 10-12Mbps from ip network.
Just wanna know is it normal?
& if 165 users can cause 50% utilization what will happen for 500+ users??
I’m shifting all users to MT & m worried about this.
We made performance improvements, so check the CPU usage in next release. We have tested UM on several thousands of active users on an old Celeron PC, 333MHz, so there should be no problem on a QuadCore PC.
If you have specified rate limits 512kbps or lower, it is normal, that you cannot get more than 1Mbps :slight_smile:
Have you tried throughput, using unlimited profiles?
The problem was related to saving two separate column ordering for “Sessions” and “Active Sessions”. Now there is only one ordering for Sessions (used also for Active Sessions). The same applies to Active Users.
yea i know it :laughing:
Thanks for solving it
Share user default is unlimited can you please make it 1
because we cannot set it while adding new users & almost everyone will keep it 1
asus
in A Session when i select user & do remove or close their session is ended in UM but still thier connected to router & they can surf & download.
Is it ok? :confused:
