v4.3 on wireless 5.8 backhauls
New story same as old story (v4.3 as v4.0,1,2) - as soon as I load v4.3 on RB433 with 5.8 PtoMP * 8 - constant drops and fluctuating latency off the chart.
Download v3.28 and IMMEDIATE connect on ALL interfaces and NO DROPS and NO FLUCTUATION!
Now somebody PLEASE explain this to me!
RTS-CTS doesn’t make one iota difference.
I don’t DARE put v4.3 on my APs - god only knows what would happen there with 50-100 connections.
This can’t be a wds / data transaction issue - it seems more like a rf control issue - kinda like 4 years ago when NONE of my APs could hold a connection for 6 months until rts-cts was re-instituted(?).
Am I crazy?
I would love to have the features that v4.+ purports to have but when will it be usable?
OK - I needed to get that off my chest.
Now - v3.28 is kicking ass so it’s not like I am in dire straits here - and it isn’t like there are a lot of hot contenders out there to replace MT - there aint! So I’ll continue to bide my time and only bitch once in a while. It’s like waving candy in front of a baby tho!
:slight_smile:
Love you guys - MT rocks!
Your a good man Normis! :slight_smile:)
I’ll go away now - :stuck_out_tongue:
are you using nstreme ??
if yes … the problem is there
4.x doesn’t work correctly with nstreme too with old 802.11a mode
Really??? I use nstreme thru my entire system!
So what are we to use then? - nstreme was/is awesome for thru-put.
And what do you mean by “old” 802.11a?
Thank you
I just switched my whole network over to 4.3, works awesome. I use nstreme. I will post if I have any issues.
Just some sharing..
I upgrade from V3.27 to V4.3.
The thing i found is, the ping time will be better with no the problem as mentioned above.
Did you check the boot loader?
/system routerboard print
if the upgrade-firmware is a different version than the current-firmware, be sure to do:
/system routerboard upgrade
No problems with my whole network converted. Now 4.1 has cpu issues. 100% cpu for no reason.
Try this:
http://wiki.mikrotik.com/wiki/Fix_Broken_Wireless_Following_an_Upgrade
The script is meant for clients or remote (other end of a wireless link) radios.
You will still get the gist of what has to be done.
