did upgrade from 4.11 Level 6
to v5.0rc5. (X86)
I have CPU Intel Core2 Quad Q8200
MB S3210SH +ICH9R.
In WinBox watch “System - Resources”:
CPU Count: 1
Hardware: Multi CPU - Enable
Why 1 CPU, if have 4 сore?
to v5.0rc5. (X86)
MB S3210SH +ICH9R.
CPU Count: 1
system hardware
set multi-cpu=yes
I did it - did not help. And in the console throws:
“Echo: system, info, critical Enabled multi-cpu setting, new value will take effect after reboot”
But, reboot does not solved this truble
Check in bios mulithreding option is enabled?
O ! Yes! Thank you very match.
